Installing 91Z28 grill & fog lights on 90RS
Hello,
I have contacted several people and gotten different answers from all of them....I want to remove the louvered grill on my 1990 RS and install the 1991 Z28 grill w/fog lights.What modifications will be necessary to accomplish this?I have found the grill,lights,relay,etc but am assuming there are brackets required as well but cannot find them or any info as to where the brackets need to be mounted.
TIA
TIA
Car: 87 GTA
Re: Installing 91Z28 grill & fog lights on 90RS
Been there, done it....
Its a direct swap, no mods really, unless you consider having to drill holes for the license plate bracket a mod.
Obviously, wiring & mounting brackets for the fog lights, but the holes are all already there.
Thanks for the reply,
I was getting bad info from people that the 91 Z28 grill would not fit on my 90 RS.My car is at the body shop now for paint and i will be picking up the grill/lights on Monday.Now i just need to find the brackets.If anyone has a set...LMK. Also, what year cars have these same brackets?
THANKS
THANKS
Car: 87 GTA
I swapped the RS grille out for the Z insert. Just bought aftermarket lights.
I had my 92 back in 96, so getting stock lights was still $$$$$$$$$.
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
yep i did the swap on my old rs also. everything bolts right up
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
yes its very easy what i did was actually with the fog lamps was i boought some blazer cheapos for now they looked OEM but i didnt have the bracket so i mounted the fog lamps a little farther back not to much and then put mesh in front of them 2 days later that saved me since i hit a little rabit and it was caught in the mesh all i had to do was replace mesh not to bad if i can ill take some pics of it and post them
I already paid for the 91 Z28 grill and fog lights...$$$$$ but now i cant find brackets.Even tried the bone yards with no luck.I believe that the brackets that will work were from 85-92 but im not sure? Anyone know ?
TIA
TIA
Car: 1992 camaro
Axle/Gears: 3:73
Try the classifieds on here there was a few sets floting around a few weeks ago.
THANKS for all the help
