Anyone upgraded to better headlights?
Old Mar 20, 2008 | 02:12 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
I have been considering changing out my headlights to a higher watt bulb. Something that would give me a brighter beam, especially on the high beam side. I thought I'd seen somewhere there is a better bulb that fits in the stock location.
Has anyone used headlights out of a different vehicle? I noticed that my sons 300ZX has a lamp assembly which looks like it would work with some modification to the bumper cover/head light area. Might be a cool look with the bulb lense sort of filling the area in. Kinda like those "aero" covers over the bulb.
Old Mar 23, 2008 | 01:43 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Re: Anyone upgraded to better headlights?
I upgraded my headlights so to speak. I just bought the ones that are by sylvannia at autozone. They were 20 bucks a headlight and they are supposedly HID, they work tons better than the normal ones and i can see alot better and further.
Old Mar 23, 2008 | 02:27 PM
'86 Camaro BoSs's Avatar
Car: 1992 Camaro RS - 1971 Chevelle
Engine: 3.1L - 5.7L
Transmission: T-5 - TH350
I think your refering to silverstars?.. if so taht's what i have on my camaro now, they are great if your on a budget.. and they make the regular one's i had on the car before look like crap..
and also if you decide to do the 300ZX thing please post pics of, i've heard people on the fourms talk about doing it but i've never seen the finished result.. and i'd imagine it'd look cool
Old Mar 23, 2008 | 06:31 PM
Saber's Avatar
Yea thats what i have the silverstars, they really put the old lights to shame. The 300ZX thing seems like it could work im interested to see what a finished product will look like.
Old Mar 23, 2008 | 08:49 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I upgraded my headlights in my TA....upgraded to a digital HID system...
6000K....looks like an air plane....I also recently upgraded my foglamps too....this is by far the brightest light system I have ever seen.....
Old Mar 23, 2008 | 09:03 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Any of the Silvania's are NOT HID's.
I was gonna do the H4 housing swap, but after I plugged the silverstars (H4 bulb) into my H4 housing for a test, they were MUCH BRIGHTER on bright, but my stock headlights were brighter on regular. And since you use your regular beams a lot more often....
Also. Do NOT use the Motorcycle H4 bulbs that are 100w. Those are much brighter than your current high beams, and there are a bunch of Honda's rolling around with them, and I just wanna pull the drivers out of the cars and beat them senseless for making me blind at night.
Old Mar 24, 2008 | 06:45 AM
McGuireV10's Avatar
https://www.thirdgen.org/headlightupgrade
Old Mar 24, 2008 | 07:17 AM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
So are the silverstars "plug and play" or do they need to be worked in? Also i haven't seen these anyone got a pic?
Old Mar 24, 2008 | 07:28 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
silverstars are plug & play . look like stock .
Old Mar 24, 2008 | 07:22 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I got the Silverstars all the way across -high and low. Love 'em. Now if I can only get silverstars for my fog lights....
Old Mar 27, 2008 | 10:59 AM
James49's Avatar
Car: 1991 Z28
hey has anybody tried the clear lenses from yearone?
here is the link, i'm thinkin bout putting them on my 91 z but for all 4 they're expensive...
http://www.yearone.com/serverfiles/f...ain2.asp?cat=G
Old Mar 27, 2008 | 12:57 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I did the housing swap with some Hella housings and I love the housings, very high quality, but my experience is the same as your test, low beam sucks big time. I'm looking for an alternative to the silverstars for more low beam performance.
Old Apr 15, 2008 | 07:42 PM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
You have to swap some of the wires on the harness for them to work correctly. There are 2 wires that need to be swapped. They may have the exact same plug, but the wire configuration is different.
Old Apr 16, 2008 | 08:35 AM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
i upgraded my headlights with the Hella Vision Plus kit that takes the H4 bulb and installed the Painless H4 conversion harness to go along with it and put Osram Silverstar H4 bulbs in. all i can say is WHAT A DIFFERENCE! the new bulbs/ housings make a HUGE difference. also the harness makes it so you can go up to 150W bulb without any problems if you wanted to without worrying about burning up any stock wiring. right now my bulbs are 55/60W but i bet if i put in Hella 80/100W or even 100/130W bulbs it'd be even better, but i don't really wanna go illegal. i think this has been one of the best and most beneficial upgrades i did on my car.
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
Veaceonee
Sep 29, 2016 08:15 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
