Paint without prep?
Old May 29, 2008 | 05:08 PM
wshbrn91's Avatar
Car: 1986 Z28 Camaro
Engine: Rebuilt 82' 305
Axle/Gears: Non-Posi stock =(
Paint without prep?
Hello.
I am doing an engine swap this weekend. I was thinking.. When i pull the old engine. If I pressure wash it, and tape stuff off, can i just put a coat of paint over the old paint? I just want it to look moderatly better than it does right now.
Or will it just not work out.
-Andrew
Old May 29, 2008 | 07:44 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Paint without prep?
wetsand the old paint with 400 grit and you should be fine.
Old May 29, 2008 | 08:11 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
At least use a red scotchbrite pad. Doesn't matter how clean, if there's no sanding, the paint will just flake off and look horible.
Old May 29, 2008 | 09:16 PM
wshbrn91's Avatar
Okay thanks... I guess ill do the red scotchbright pad thing. I hear of those alot, ill check it out..
THANKS!
-Andrew
Old May 29, 2008 | 11:43 PM
jimmyj2000's Avatar
Car: 88 Formula 350
Engine: l98
Axle/Gears: 3.23 9-Bolt
After the scotchbrite pad, you should still clean it with some type of solvent that will remove all of the left over oil residue. Your local auto parts store should have some stuff over in the paint section that is used specifically for this purpose.
Old May 31, 2008 | 07:32 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
i am kinda in the same boat. i have my car almost ready for primer and want to do a two tone. right now the car is black and i have the body sanded down pretty well but the door jams i only scuffed with 100 grit then some scotch brite. if i were to paint over the black with burnt orange would the orange come out darker then on the parts of the car that i do use gray primer on. i just dont want to have to block sand the primer in the door jams since it is so thight in there. i am going to use base/ clear paint if that matters and i should have plenty, so if laying it on thick will work that would be great.
Old May 31, 2008 | 07:40 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
if you do 3 coats all over the difference shouldnt be very noticeable (if at all), and personally since its door jams I wouldnt worry too much but your other option is to use a sealer over the whole car, that way it'd be all one color before spraying.
Old May 31, 2008 | 07:56 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
I don't think you are going to be happy with it if you scuffed it with 100grit. Too late now but at least 320 might have been a better choice for scuffing it up.
Old May 31, 2008 | 07:59 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
yeah I forgot to mention that in my post, I scuffed mine with 400 grit then a scratch pad
Old May 31, 2008 | 09:29 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
gosh,this thread is turning into a prep work thread ain't it?
Kinda funny reading the title now. Any progress on your car yet Tmic?
Old May 31, 2008 | 09:37 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
yeah check out the thread "finally laying some paint on" in the firebirds section on the appearance board. but back to topic now...
Old Jun 3, 2008 | 02:35 PM
wshbrn91's Avatar
lol you hijacked my thread.
but thanks guys
=D
-Andrew
Drone358
Sep 21, 2015 08:54 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
TheExaminer
Sep 6, 2015 11:40 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
