Hatchback alignment
Old Jul 17, 2008 | 11:49 AM
Romilin's Avatar
Hatchback alignment
I recently purchased a 92 v6 t-top and the hatchback isnt ligned up correctly. At the top near the hinges the gap is big anough to fit my finger in and at the spoiler it sticks out about a half inch. Is there an adjustment of some sort to line this up correctly?
Old Jul 18, 2008 | 04:46 PM
Chrisry1995's Avatar
Car: 89 Trans-Am
Engine: 5.7 TPI
Re: Hatchback alignment
There is a gap at the top that's pretty big, like you said about finger wide. Check the glass on the sides and see if it's even on both. The metal "decklid" is very adjustable. That's what is probably out. You can losen the nuts towards the glass and will be able to move that around on the glass. Should be able to push it up. Is the metal lid even on the sides?. You can also adjust the hinges too, but first check to see if someone messed with the metal lid first.
Old Jul 18, 2008 | 07:16 PM
Romilin's Avatar
Yeah the decklid with the spoiler on it is sticking way out, but the glass on the sides is perfectly even......
Old Jul 22, 2008 | 11:33 AM
Car: 89 Trans-Am
Engine: 5.7 TPI
You know, after posting, I looked at my car and sure enough the deck lid is sticking out past the end of the car about 1/4" or alittle more!!! I wonder if that is normal??? Kind of makes me think Know you got me thinking about pushing it in.
Old Jul 23, 2008 | 05:58 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
it is a very common problem
check this out, its under the technical articles section of this site
https://www.thirdgen.org/hatchalign
Old Jul 23, 2008 | 08:44 AM
Romilin's Avatar
Wow thank you VERY much, I cant believe I couldnt find that link, it was EXATLY what I was looking for!
Old Jul 23, 2008 | 09:39 AM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
i have yet to see a thirdgen with a perfectly aligned hatch
Old Jul 23, 2008 | 10:00 AM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
my 86 iroc-z has a perfect hatch :-)
Old Jul 23, 2008 | 10:20 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
here's my thread on this exact same issue..
https://www.thirdgen.org/forums/body...alignment.html
Old Jul 23, 2008 | 12:36 PM
Brennan's Avatar
that is a beautiful car
Old Jul 26, 2008 | 01:35 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
dont raise the hatch like the article says, thats busted glass waiting to happen. i removed my struts, dropped my hatch motor because the adj will move it from the set postion and cause the hatch case to bust if it isnt resting right and i loosend the bolts at the interior of the car.
then i left the hatch down and it scooted around to where i wanted it and then i cenched the nuts back down.
after i re adj my hatch pull down and all is good. i also did this myself without help.
Old Jul 29, 2008 | 12:23 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ive got a thread out there on this subject as well
i went through all this on my 82 last fall
i swapped my glass and reattached my original spoiler deck
it was out of aligment pretty badly like yours was
now its perfect
i alifgned the glass straight first and then set the deck on with the urethane and aligned it and bolted it tight and thats it
never seen one that wasnt aligned right
not from factory
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
evilstuie
Sep 24, 2015 02:31 AM
89 formula TPI
Sep 20, 2015 10:54 AM
