GTA fog lights as reverse lights....
Old Jul 19, 2008 | 03:24 PM
Stephen's Avatar
Car: 87 GTA
I think it looks pretty good.
Attached Thumbnails GTA fog lights as reverse lights....-reverse-fog-lights-high.jpg
Old Jul 19, 2008 | 04:42 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: GTA fog lights as reverse lights....
just my opinion but it looks bad.
edit: off topic but your tail lights sure could use a buffing!
Old Jul 19, 2008 | 08:39 PM
Stephen's Avatar
Car: 87 GTA
What do I expect from a little KID...You don't like? Fine. Say so. But the part is totally uneeded. The internet makes everyone brave hiding behind screen names.
Old Jul 19, 2008 | 08:52 PM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
Doesn't look totally out of place. Bit I do prefer original if I were to decide.
Old Jul 19, 2008 | 08:55 PM
Stephen's Avatar
Car: 87 GTA
The stock reverse lights are still up there, but with the black grid in them, they are virtually useless.
Old Jul 19, 2008 | 09:09 PM
SinZ's Avatar
Car: 89 Iroc Z
Engine: 5.0
I think it looks good...
But hmmm... DOnt know if your at an angle or something, but the left side light looks like it comes in more than the right one...
Old Jul 19, 2008 | 09:39 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
yeah but that comment is totally called for?
but on a serious note, I think the stock is much better, maybe its just that the lights are way off center in that photochop though.
Old Jul 19, 2008 | 09:50 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
stock reverse lights aren't bright enough for ya?
Old Jul 20, 2008 | 03:52 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
What about putting them down in the ground effect portion, and farther outboard? My thinking is that would sort of match the way they are in the front. I think it would look good too if they were molded in a couple inches, also like the way the fronts are.
Old Jul 20, 2008 | 08:17 AM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
That was my first thought when I saw it too.
Old Jul 20, 2008 | 08:37 AM
Stephen's Avatar
Car: 87 GTA
My first PS was below that line/seam....Didn't look right to me, so I moved them up. Too much open space above, so I moved the up. I could move them outwards..
Attached Thumbnails GTA fog lights as reverse lights....-reverse-fog-lights-low.jpg   GTA fog lights as reverse lights....-rear-fog-lights-wide   GTA fog lights as reverse lights....-rear-fog-lights-wide
Old Jul 20, 2008 | 08:48 AM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
I didn't realize it at first, but we're looking at photoshop here? You haven't actually done this yet, right?
Because that would mean it's not too late...Don't do it. It are the not look good.
Fog lights are really too bright to use as reverse lights. The stock lights are plenty bright. They can be seen from many hundred yards away, which is more than enough.
Old Jul 20, 2008 | 09:00 AM
Stephen's Avatar
Car: 87 GTA
Yes....A 'chop. Since you didn't realize, I guess that means I did alright!
If the stock lights were bright, I wouldn't even be thinking about this...They may be SEEN from way away, but that doesn't you can SEE way away real good, while backing up.
The pic I used is OLD (notice it still has the original 3rd gen spoiler, not my 4th gen wing?) and the tail lights have recieved a good polishing since the pic.
Old Jul 20, 2008 | 09:17 AM
black89ws6's Avatar
I've never thought of reverse lights as providing illumination, like headlights. I've always thought of them as signaling driver intent to reverse, in the same way as turn/brake lights signal intent to turn/slow down. Maybe I thought that way because I've never had a car with bright reverse lights, and most of them have had tinted windows, which pretty much negates rear night vision anyway. I've just gotten in the habit of riding the brake pedal, to illuminate with brake lights when needed.
If additional reverse illumination is what you're looking for, I would think this would do it. Have you tried putting brighter bulbs in the stock reverse lights? If it were me, I would go there first.
If you do put them on the car, I would go for lower, and farther outboard (just my $.02)
Old Jul 20, 2008 | 09:37 AM
Stephen's Avatar
Car: 87 GTA
You live in town, don't you? I did too, in an apartment, until about 3 months ago. Now I have a house. Backing up was never a problem, in town, with all the lights.
Now I'm out in the county, very few street lights & I back into my car port, not pull straight in..
I've been wanting brighter lights & I have a spare set of GTA fog lights, so the thought of putting them to use occured to me last night.
Old Jul 20, 2008 | 06:32 PM
Fyrstorm's Avatar
Car: 86 Trans Am
Have you seen the bulbs that are supposed to be twice as bright? I had them on my jeep cherokee and I had the windows tinted and I saw squat at night even with the streetlight at the end of my driveway. I put those in and it became marginally better, but enough for me to see.
Old Jul 20, 2008 | 06:37 PM
Stephen's Avatar
Car: 87 GTA
Yeah....I've tried those too. Not much help with no city lights around. I live very much out in the country.
Old Jul 20, 2008 | 06:41 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
i went with 50W lights in my B/U's.... its actually a 50W incandescent "old school driving light" bulb, it has the same base and all as the stock B/U....aprox $4 per bulb at Advance Auto
very bright, no problems backing up now
Old Jul 20, 2008 | 07:23 PM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
Hey Stephen, have you considered trying to cut the reverse light reflector and somehow mounting the fog lights behind the lenses?
either that or some super bright LED's maybe?
not sure if those would be bright enough for you though...
Old Jul 20, 2008 | 07:30 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Maybe a motion sensor in your carport would help...
I like how you think, but I do not like they way they look. Maybe a different style of light or maybe put them and somehow hide them with plexi glass. I dont know. Square lights would be the way to go, but I dont know what it is about they way they look. Maybe get rid of your third brake light and make it into a reverse light.
Since your GTA is white, they third brake light might look good as a reverse light.
Old Jul 20, 2008 | 07:52 PM
Stephen's Avatar
Car: 87 GTA
I wouldn't cut my tail light housings up.My luck...I'd screw something up & I'd ruin a set of GTA lights.
If I was gonna cut the light themselves, I might do this...
Attached Thumbnails GTA fog lights as reverse lights....-lights-centered-wide.jpg
black89ws6's Avatar
I live 2 miles past the end of the pavement. It sucks to drive an fbody on a gravel road.
My driveway, and the 'bird's parking spot is such that I pull in forward with clear field of vision, and when backing out, there's nothing behind me for me to even turn around to look at...just clear open space.
Old Jul 20, 2008 | 08:02 PM
Stephen's Avatar
Car: 87 GTA
Actually, my whole house is remote controlled lights! Not just a motion sensor, but a handheld remote control. The range isn't real far, but I get about halfway into my driveway, then I can turn on mycar port lights, from inside my car. That helps, but I better hope I'm lined up to begin with pretty close, or I'll be pulling forward towards the road, lining up better, then backing up again.
The pic I used is an old one & I now have a 4th gen light. I'd hafta come up with a clear clears, that is shaped to fit. A 3rd gen light lens would be simple, since they are flat.
Old Jul 20, 2008 | 09:49 PM
FYRCHKN's Avatar
Engine: LT-1
Fog lights in the rear is actually a great idea. For the past year and a half I've been trying to come up with a hide-away design for a pair of bright lights in the rear of my car. I don't necessarily need them for backing up (my reverse lights don't work since the tranny swap anyway) I just want them for people that like to get right up behind me and hit me with the high beams.
Old Jul 21, 2008 | 07:39 AM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
i have the same problem in my area
they just dont seem to care that their precious cadalacs headlights are blinding you!
already took care of that on the front of my car, i turned my fog lights up and to the left a little, just enough to where if i flash em a couple times it gets the ******* to turn their high beams off
my brights just arent bright enough to do the job, lol
but thats just not the topic at hand now
back on subject now..
Stephen- you know, on a second glance, your first photoshopped picture you started the thread with actually looks pretty good
Old Jul 21, 2008 | 05:32 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Stephen- in post #11 that first photoshop actually looks really good. I think they just need to be below the lip.
Old Jul 21, 2008 | 06:12 PM
Stephen's Avatar
Car: 87 GTA
Hmmm...I could kill 2 birds with 1 stone & have them aimed up just enough that tailgators/Hi-Beam runners, could be taken care of, with a seondary on/off switch!
Old Jul 21, 2008 | 06:16 PM
Firebat's Avatar
I see the purpose of it, to have better lighting when backing up. However, I've seen H3 bulbs retrofitted into a normal bulb housing on ebay before(not homemade either) made for reverse lights. You could even make your own using 100+ Watt H3 or H4 bulbs. For the short amount of time you run reverse lights there would not be a heat problem. You may want an upgraded wire harness(if you run 100 watts). I'm just saying there are simpler solutions out there for brighter reverse lights.
Something like this but without the backup alarm on it: http://cgi.ebay.com/ebaymotors/1-Plu...ayphotohosting
Old Jul 21, 2008 | 06:21 PM
Stephen's Avatar
Car: 87 GTA
Considering my cut & modified harness, for the STS tail lights, cutting the wires isn't a problem for me. Cutting the actual housing themselves would be. I've even got a spare tail light wire harness.
Rear bumper cover cutting....I've already got a spare front & rear bumper cover spares, in white no less, and a full set of ground effects, also in white. That kindof stuff isMUCH easier to come bythat the tail lights themselves.
Old Jul 21, 2008 | 06:24 PM
FYRCHKN's Avatar
Engine: LT-1
Hey Stephen, I know how to remove the grid in the reverse light section without messing up the rest of the grid if you need/want me to. Don't you have a spare set to modify?
Old Jul 21, 2008 | 06:29 PM
Stephen's Avatar
Car: 87 GTA
I do have a spare set. I wasn't sure if you still wanted them, or if you were gonna stay with your custom gridded ones.
But no...Thanks for the offer, but I don't wanna mod them....yet.
jaridjohn
Jul 8, 2024 03:49 PM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
