These tail lights will fit ....
Old Sep 2, 2008 | 08:04 AM
fyrebird68's Avatar
... which years?
They are from my son's 91 TA, but I am sure they fit other years. I'm getting ready to sell them and I want to accurately represent them.
Thanks,
Bob
Attached Thumbnails These tail lights will fit ....-img_1380.jpg   These tail lights will fit ....-img_1383.jpg
Old Sep 3, 2008 | 01:33 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Re: These tail lights will fit ....
They should fit all years, now if there are enough bulbs is the question.
Old Sep 3, 2008 | 01:49 AM
Stephen's Avatar
Car: 87 GTA
Those will drop into 90 & earlier & just need the center section. 91/92 have no center section, just 2 wider pieces for lights.
But those have 4 bulbs per side, whereas GTAs (not sure if any others got the "GTA" lights) have 3 bulbs per side
Old Sep 3, 2008 | 02:58 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
82-90 firebirds (Will fit all models)
Old Sep 3, 2008 | 07:46 AM
fyrebird68's Avatar
Now I'm confused; these came off of a 91 TA.
Old Sep 3, 2008 | 09:33 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
then those were on the wrong car...they will fit 85-92 firebirds and formula's, and depending on year, the center section was changed (difference of only color, 85-90 had a white bird, 91/92 had a red bird). If they belong on a 91, and it was an actual TA, then it should be a 2 piece tail light set. Do not be confused though, if the car has a body kit identical to the trans am, it does not make it a trans am. There was a sport appearance package on base model firebirds to look identical to trans ams. So not going into too much history, those will fit 85-92 firebird/formula's with the addition of a center section.
Old Sep 3, 2008 | 05:41 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
maybe this will help you.This car is a 91 t/a.
You notice the taillights look nothing like yours correct? Thats because 91-92
t/a's&gta's only had these lights in the pic.
If yours came from a t/a,someone along the cars life installed base model firebird/formula ones.
Old Sep 3, 2008 | 11:22 PM
What may have happened, is that someone replaced the originals with the firebird lights. The taillights seen in the pic above can be hard to find in good cond, and if they are in good cond, they can be really expensive... I know!! LOL
Old Sep 4, 2008 | 10:27 AM
10secondhopeful's Avatar
Car: '84 Z28
good luck selling them, it shouldn't be to hard with the amount of people that get rear ended
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
