t top weather stripping
Old Oct 1, 2008 | 11:21 PM
rad russ's Avatar
Car: 1987 IROC Z
Engine: 5.7
I was wondering if someone could tell what brand of weather strippinis best I just spend 500 on new gm stuff they have in in the car of 3 months they are tearing and cracking. To say the least I 'm a little pissed. An advice would be great.
Old Oct 2, 2008 | 04:49 PM
madhatter's Avatar
Re: t top weather stripping
try hawks third gen. they are really reasonable in price and it is really good quality stuff. it is a gm repo so it fits really well, i have no complaints about it. i have also read that to help prevent cracking is to cover the weather stripping with vasoline and let it soak in periodically to help keep it from drying out and cracking.
Old Oct 2, 2008 | 11:55 PM
rad russ's Avatar
Car: 1987 IROC Z
Engine: 5.7
Thanks I will consider them.
Old Oct 3, 2008 | 02:10 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
If we are talking rubber weather stripping vasoline would be a BAD idea.
Petroleum based products deteriorate rubber.
Someone please correct me if I am wrong.
Old Oct 3, 2008 | 10:42 AM
madhatter's Avatar
http://www.chevelles.com/forums/arch...p/t-57710.html
http://www.nissanforums.com/car-care...stripping.html
just a few that i have read, so yeah please correct me if i am wrong because i don't want to **** up my weatherstripping that i just put on there, but i would like to make sure that i keep tham for drying out.
Old Oct 3, 2008 | 11:53 AM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
I've heard of using vasoline also, but only on otherwise old or bad weatherstriping as a means to bring some life back into it.
Old Oct 4, 2008 | 04:00 AM
Car: 1985 Z28
Hmmmm.
I have been building water cooling systems in PC's for years and a trick people used to use was to coat the hose barbs with vaseline until someone found out it started rotting the hoses. That's when teflon tape became the sealant of choice.
Maybe they were using latex condoms for tubing
Either way, with all these people doing it for years and no bad results, I say power to ya. Was just trying to save you some headache.
Old Oct 6, 2008 | 07:27 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Just because the weatherstripping came from the dealer doesn't mean it's OEM. You need to order OEM by part number. Some dealers use OER or another type which I have heard falls apart. You definately don't want to Vaseline on the seals. it will break them down. Something doesn't sound right about $500 seals and breaking down already.
Old Mar 6, 2009 | 11:32 PM
VRROOMmaster's Avatar
Car: 1970 SS
Transmission: TH350
Axle/Gears: 12 Bolt Posi 373
This would be better than vaseline, armor all or any other petroleum type products. It is water based.
Part Number: # K89480
OER NATURAL SHINE MATT FINISH PROTECTANT 16 OZ BOTTLE
Can be used on both interior and exterior surfaces such as rubber, leather, vinyl and plastic. It brings back the like-new feel and look to your vehicle that also protects against damaging UV sun rays.
  • Guards against UV damageReplenishes vital nutrients with every application
  • Cleans normal surface dirt quickly and easily
  • Leaves surfaces dry, healthy, shiny, and conditioned
  • Also for all exterior rubber, and door seals
  • Protects against discoloration and cracking
  • patented UV absorber in All Guard X -Natural Shine Dressing penetrates and act as a protective barrier against harmful rays that cause premature aging, cracking, fading and peeling.
  • engineered to work like a lotion soaking into new and dry, rubber or vinyl and aiding in prolonging and strengthening the surface.
http://www.classicindustries.com/con...rchCatalogId=1
1992 Trans Am
May 10, 2023 07:19 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
angel2794
Sep 8, 2015 06:22 PM
InfinityShade
Sep 5, 2015 06:38 PM
