Easy, Hard, or a huge PITA?
Old Nov 5, 2008 | 04:08 PM
10secondhopeful's Avatar
Car: '84 Z28
I have a 1991 Camaro RS but its been wrecked, some idiot ran into the rear end, the glass is busted out and the whole hatchback part of it is all ****ed up, the tail lights and bumper are messed up too, the rear fender area on both sides i think is good condition though. none of the frame is messed up. I can get the hatch piece, the tail lights, and the bumper for pretty cheap, i just need to know how hard its ganna be replacing it. And the best way to do it... thanks....
Old Nov 5, 2008 | 04:14 PM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
Re: Easy, Hard, or a huge PITA?
hey man, as long as the frame and the quaterpanels are in good shape. it shouldn't be that bad. the hatch should be taken off first so the glass is not a hazard. then the tail lights and then the bumper. That way you put the bumper on and then the lights. and when you put the hatch back on you already will have everything back together. Get a buddy to hold the hatch with you. -Matt
Old Nov 5, 2008 | 05:43 PM
Fbodywarehouse's Avatar
Solid afternoon's work but well worth it, if the structure of the car is not caved in you are in like butter on bread
Old Nov 5, 2008 | 10:15 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Be prepared for some rear body panel damage where the tailights go in. But really the rest of it is pretty simple to work on.
Old Nov 6, 2008 | 10:28 AM
Car: '84 Z28
Thanks guys, its a relief to know its not ganna be too bad. The lights arn't to badly damaged, one set is all messed up, the other only has partial damage. thanks again
Old Nov 6, 2008 | 10:31 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
you won't really know how much damage you have until you take that bumper cover off. If the impact was enough to break the rear glass, the odds are that your rear impact bar took a pretty good hit. You'll probably be looking at replacing that bar and possibly need some repair work on the "frame" mounts for the impact bar. As mentioned above, you may also have damage to the body behind the taillights.
Do you have any pictures of the damage to post? That may help us guess at what damage lies beneath, but the only way to know for sure is to start disassembling and see what you have.
Old Nov 6, 2008 | 11:16 AM
Car: '84 Z28
actually i got a good look at the bumper area, it pretty much broke most of the bumper off, it looked fine but i'm not 100% sure. i don't have any pictures but i might be able to get some, but not for a while
Old Nov 6, 2008 | 12:43 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
This seems contradictory to me. Which one is it? ... or do you mean that most of the bumper cover was torn off and the impact bar looked fine? That's hard to imagine... let's see the pictures and go from there.
Old Nov 6, 2008 | 12:48 PM
Car: '84 Z28
ya, the cover is ruined, but the bar looked fine. i won't get pictures till tomorrow
Twin_Turbo
Mar 14, 2016 10:10 PM
92-Formula
Dec 12, 2015 10:34 PM
Breazlan
Sep 25, 2015 11:20 AM
Ragtop Man
Sep 12, 2015 12:23 AM
Randomtask2
Sep 7, 2015 05:06 PM
