Best way to break into my own car
Old Dec 26, 2008 | 06:18 PM
vargasjc's Avatar
I locked my car keys inside the car...what can I do?
What would be the best way to get in??
I used a coat hanger to get into my chevy impala...a long time ago...and it word fine...but on the 89 firebird...it looks really hard to do because of its door mechanism
Would it be hard to just break it with a screw driver?? and break it open and then just replace door lock set??
Whats the easiest/cheapest way to get my keys/car back?
Old Dec 26, 2008 | 06:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Best way to break into my own car
call AAA, or use a brick
a service station might have the tools to open it, or a local cop.
Old Dec 26, 2008 | 07:07 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
if the door mechanism is just like my 89 camaro you can easily break in by using a thin metal ruler and inserting it down the glass, inbetween the handle and key hole.
You'll beable to feel it come into contact with the rod that locks the car. Push down hard on it and it will unlock. takes some time to do it if its your first time. I've locked my keys in my car several times and always used the ruler to break in
Thirdgens are easy to break into.
Some say you can easily pick the rear hatch lock but i tried for awhile and couldnt do it
Old Dec 26, 2008 | 07:17 PM
buell's Avatar
Car: 87 camaro iroc
Engine: 5.7L
do u have t-tops? anyway u can get in ur rear trunk? lol
idk about u but where my t-tops meet the class of my door there is a pretty good gap there....
i personally need more info (pics) on the car to come up with any ideas...
havent locked my keys in the car yet and so dont know from experience the best way... hope u manage to get it open without damaging ur car too much
Old Dec 26, 2008 | 07:45 PM
vargasjc's Avatar
its a hardtop
Old Dec 26, 2008 | 08:00 PM
UDAMON's Avatar
Car: Mazda Protege5
try prying the window out at the top where you can grab it with your hand and you should be able to pull it out enough to reach inside and unlock.
Old Dec 26, 2008 | 08:29 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
go to a parts store and ask for a slim jim. its a thin piece of metal with hooks on the side. its about 10 bucks and is specificaly made for breaking into cars. it wont damage anything. or you can cut a piece of wire from a chain link fence, its easily pliable but is still much firmer than a coat hanger and you can get longer lengths
Old Dec 26, 2008 | 08:36 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
AAA. then get spare keys made and keep one on u at all times, like in something that u put in back pocket, usually holds money........
Old Dec 26, 2008 | 09:10 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
And steal, BEWARE.
WHy when I had a stock hatch I removed the glass 3rd brake light.
Makes most think you got Vats as when they got it, the glass light was moved to the wing. Illegal if ya don't but it back on somewhere else but might get em to move on.
Old Dec 26, 2008 | 09:15 PM
shibbykins's Avatar
Car: 91 RS Vert.
Engine: 350 TBI cammd
gonna have to try that
Originally Posted by Gumby
And steal, BEWARE.
what???
Old Dec 26, 2008 | 09:47 PM
85TransAm406's Avatar
Car: 1985 Trans Am
the way the wrecker guy did it is he pried out the very top of my driver's window, put in a plastic wedge, then used a straight rod with a right angle end on it to push the inside door lock slide. He went at it from the rear of the door. could use a stiff coathanger.
Old Dec 26, 2008 | 09:54 PM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
I was able to do that on my 87 formula hardtop when i locked the keys in.
Old Dec 26, 2008 | 10:18 PM
1LOMARO's Avatar
Car: 89 Camaro, 94 z-71,98 Camaro
Engine: none, 350 tbi.sixxer
Transmission: none, 4l60e,auto
Axle/Gears: none, 3.73
I used a thick paint stir stick when my loving wife locked my keys in my 88 TA..... took all of 10 seconds to get in! Just find the rod and give it a suddle pop on the end of the stick and "ta-da" ...... it should open!
Old Dec 26, 2008 | 10:22 PM
MYZ28NH's Avatar
Car: 91 Z28 Convertible
Ihad a dodge van and i locked my key in it. Called triple A. The guy pulls up and he's talking on a cell phone. Tells the person on the other end...hang on a sec I gotta do a lock out. He had my door open in less than 60 sec I could not believe it. I was shocked. why do we even lock our doors? Did what was decribed above.
Old Dec 27, 2008 | 12:17 AM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
*Goes outside to break into my topless convertible Camaro*
Old Dec 27, 2008 | 12:21 AM
shibbykins's Avatar
Car: 91 RS Vert.
from one vert owner to another.... thats hillarious
Old Dec 27, 2008 | 12:23 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
When I had my new windshield put in I wasn't home and my step mom gave the guy my dads Chevy Truck key not knowing and I guess it opens my door lock. So... try a Chevy key...
Old Dec 27, 2008 | 12:24 AM
JTNKTZ's Avatar
Engine: 355/350
MYZ28NH
He is one too. We bought new tops from the same guy at a very good price! Same color too!!! I just wish mine was a Z28... Lol
Either the guy broke your lock or it was already open cause that's in no way possible.
Old Dec 27, 2008 | 12:27 AM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
i haven't got around to installing the new weather stripping on my passenger side so when i locked my self out i just pried the window open put a stick in and opened the hatch and crawled in through that
Old Dec 27, 2008 | 01:17 AM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Of course it is!
Old Dec 27, 2008 | 01:22 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
20 year locks = worn... very possible.
Old Dec 27, 2008 | 01:28 AM
Stephen's Avatar
Car: 87 GTA
I've got an idea...Let's publicly post to the WORLD about how best to break into our cars & help the thieves!
This thread should not only be LOCKED but DELETED, for anyone to ever even read.
Old Dec 27, 2008 | 01:32 AM
88iroc52387's Avatar
Get yourself a slim jim from the auto store they are amazing to have laying around. Anything 95 or older usually is a breeze to pop open. Some of the new cars are quite a bit more challenging. Never had to pop my iroc but i can open my tempo and my g/f's cavalier in a few seconds
Old Dec 27, 2008 | 01:35 AM
Car: 86 T/A
Engine: 5.0 TPI
Don't worry thieves are stupid ... they only steal honda's
Old Dec 27, 2008 | 01:41 AM
Serously do you think an expirenced theif skims forums to break into cars. Half the time they bust a window, they don't nicely break in. Plus anything as old as our cars can be easily popped with a slim jim....
- Most slim Jims come with step by step instructions as well you should write the company .....
- Not trying to be a jerk... just trying to put that statment into persepctive.
Old Dec 27, 2008 | 02:01 AM
JTNKTZ's Avatar
Engine: 355/350
This guy too!
http://www.youtube.com/watch?v=sDcqkj1nCek
jaridjohn
Jul 8, 2024 03:49 PM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
Linson
Aug 21, 2015 02:12 PM
MY87LT
Aug 17, 2015 08:43 AM
Poncho92
Aug 7, 2015 08:15 PM
