Fiberglass rear deck
im trying to get some more weight off the car but am running out of ideas. I came up with a fiberglass rear deck lid (trunk) instead of the factory one but wanted to know what the weight savings would be and if worth the trouble. thanks
Re: Fiberglass rear deck
if your taking about the whole rear hatch. like a notchback. yes they are fiberglass but they weigh as much as the stock glass. plus you lose so areodynamics with the notch.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Absolutely not - you lose about 70lbd with a fiberglass notchback (at least the one I have. Not sure about the aero portion since no one has ever done real testing on it.
Also, replacing the decklid with a fiberglass one probably isn't going to save you much weight at all, if any, and you'll probably lose some strength in the decklid for mounting your spoiler. You'd probably have to use some large *** washers to spread the load.
Mathius
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
http://cgi.ebay.com/ebaymotors/Parts...1%7C240%3A1318
Heres the lexian back window. if your worried about weight, this would take a lot off. that rear window is extremely heavy.
also im pretty sure i noticed a drop of 2-3 mpg when i put mine on.
i think its ugly as hell.[/quote]
i agree, well so much for that idea. what else do you guys think i can do to reduce weight aside from whats on my sig. the car weighs about 2925 lbs. without me in it.
Car: 1984 Camaro SC
Engine: 305 V8, LG4. For now...
Transmission: 700R4, for now...
Axle/Gears: ???
i agree, well so much for that idea. what else do you guys think i can do to reduce weight aside from whats on my sig. the car weighs about 2925 lbs. without me in it.[/quote]
where did u go to find out the weight of ur car? i was thinking of going to my local dump and ask them to weight my car...i to have been wanting to save weight, without stripping the entire interior
Car: 88 GTA "Cocaine"
Engine: 350 tpi
wait a minute
here are the cons
ugly first and formost
reduction of aerodynamic
rear sight reduction-causing more thirdgen to die
taking wieght off the rear wheel- bad for street cars good for drag cars
pros
maybe if you drag race and you have fiberglass door and front clip- maybe
here are the cons
pros
that lexan back window seems like the best idea to me. it keeps the original shape of the rear end, and im sure it weighs a lot less since its not solid glass like the originals.
If he's building a track car or something, ok, but there's a reason lexan glass isn't DOT approved.
Mathius
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
Lol, I don't think that it is ugly as hell.. you just cant post pictures of them on pieces of **** and expect them too look good...
Car: 86 T/A
Engine: 5.0 TPI
Around here you can goto the truck scales and weigh your car. Often times the scales can be seen thru the window even if they're closed.
and yes the lexan prolly would be for either show cars or race cars only. winter would be hell lol. but id say if your looking to take weight off your car 90% of the time its for racing anyway. and if you want to take some weight off id look more to the interior and maybe some fiberglass fenders and hoods. just my opinion.
Car: 86 T/A
Engine: 5.0 TPI
UDAMON i actually like the old rugged look with the black wheels and primer paint. makes it look like a pissed off beast. not a fan of the rear decklid but its your car and if you like it then run it
just like im gonna run pink wheels...
... kidding kidding kidding!!!
Engine: 350TPI
Axle/Gears: 3:27
I will admit, when I first saw my car I saw the notchback as a turn off. the first words I spoke when I saw it were "Dammit its a notchback" but when I got up close it did look very good. You have to see it in person, it does look pretty good... I still might put a hatchback on mine, because the black paint keeps warping the fiberglass on the notch... it looks like hell up close now.. but its a factory AA8 notchback and is decently rare because of it, so That's why I'm only thinking about it. Oh and I cant imagine the notch being any lighter than the regular hatch, its pretty damn heavy. Oh yeah, and I'm getting an Ebach pro kit for it in the spring...
where did u go to find out the weight of ur car? i was thinking of going to my local dump and ask them to weight my car...i to have been wanting to save weight, without stripping the entire interior[/quote]
my chassis guy rolls the car and puts it on 4 scales to check the weight at each tire in order to adjust the suspension. you can also go to the nearest truck stop and use their scale, its usually only about $5-6 and you get a print out with the weight
Car: 1984 Camaro SC
Axle/Gears: ???
lol im def NOT running pink wheels lol. only color on our third gen wheels should be chrome/aluminum/black. those stupid fart cans are the ones that paint their wheels like a rainbow.
and i think the notchback is startin to grow on me, but id still prefer hatch just for the aerodynamics and the easy view through the rear view mirror.
so whats up redformula88? what you gonna do to lose some weight lol.
Here's an old pic of my Camaro - seems to be the same hatch as the red one higher up in the thread...
ive already switched back to a glass hatch, notchback is for sale. but like MichaelSparks88 said run what you like. those useless comments like BigBadGTA said just discourage those from actually doing what they like instead of what the stock ***** tell them to do
Engine: 350 tpi
man I just have to say that doing things like painting your wheels is for the people you want to customize there rides without actually doing some work or spending money which is ok
just try to keep it away from us people who are super serious about these cars
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
