Any changes in fbird headlights over the years?
Old Jan 19, 2009 | 01:22 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
I'm searching for a new headlight cover, brackets, and whatever else I'll need (hit an elk at night and the right side headlight was almost ripped out)
Are there any differences in headlights between 82-92?
Old Jan 19, 2009 | 01:38 PM
redfivexw's Avatar
Re: Any changes in fbird headlights over the years?
I believe that 82-90 are the same, 91 and 92 are different due to the new nose design
Old Jan 19, 2009 | 08:10 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Sounds like the headlight stuff is the least of your problem.
What all is damaged beside the h/l?
I have a spare 89 headlight bucket(no motor)you can have if you want to pay the shipping cost.You can probably find one in a local j/y for less than that though.
Old Jan 20, 2009 | 12:08 AM
Engine: 3.4
Well I got one. I think it was off an 88 or so. Had a nice looking 305TPI in it that I wanted.
I'll see how it easy it goes in tomorrow.
Old Jan 20, 2009 | 10:09 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
the headlight doors can be modified to fit either the 82-90 or 91 n 92
I did not like the fact that my 91 had firebird ingraved in the headlight door not only collecting dirt and wax but taking away from the smooth transitions of the frontend of this bodystyle
unfortunatly I decided to become a law abyding citizen so I put a plate on the front
Old Jan 20, 2009 | 07:23 PM
Darth Satanis's Avatar
Car: 86 Firebird
Engine: Buick 3.8 V6 Turbo
Transmission: 200r4
Axle/Gears: 3.42's
The main headlight assembly itself is the same from 82-90 & 91-92 diff headlight size
The Cover also 82-90 & 91-92 (mounting bolts in diff locations)
The frame around the headlight assembly were diff 82-84, 85-90 and 91-92
The motors 82-85 and 86-92, 2 wire vs 3 wire
Can ya tell I work at a Salvage Yard
Old Jan 20, 2009 | 07:27 PM
Stephen's Avatar
Car: 87 GTA
You left out 1 thing....The 82-90 bulbs are different sizes (bigger) than the 91/92 bulbs.
Old Jan 20, 2009 | 07:30 PM
Car: 86 Firebird
Transmission: 200r4
Axle/Gears: 3.42's
See first on my list
Old Jan 25, 2009 | 12:11 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Almost correct. 82-86 model years for the three-wire headlight motor, 87-92 for the two-wire headlight motor. Two different headlight control modules are another potential monkey-wrench for anyone repairing a 87-92 two-wire headlight system.
Lon
Ghettobird52
Jul 5, 2024 11:18 PM
okfoz
Aug 21, 2015 07:38 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
