formula hood on gta it not a proper fit look.
Old Feb 8, 2009 | 09:49 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
my hood looks like its open when its not. i always hear it from people. why does this hood not fit flush. I even turned the screws low.
Attached Thumbnails formula hood on gta  it not a proper fit look.-trans-am-rx-7   formula hood on gta  it not a proper fit look.-trans-am-rx-7
Old Feb 8, 2009 | 10:13 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: formula hood on gta it not a proper fit look.
honestly, its your bumper. There should be bracket from the bottom radiator support that goes all the way to the upper plate that attaches the bumper to the upper radiator support. Check that. I'm having the exact same problem with my Trans Am. The hood doesn't need to go down, the top of the bumper is sagging and needs to come up...//hcr
Old Feb 8, 2009 | 10:16 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
The hood itself looks fine,perhaps you have an issue with a front bumper cover not lining up correctly? I don't know but,the formula hood should fit the same as a t/a hood.
Old Feb 8, 2009 | 10:17 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Looks like the hood is a little high compared to the headlight doors to. Have you tried setting the latch down a little. And it may be the bumper is down a little also.
Old Feb 9, 2009 | 08:29 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
That hood looks like it still needs to be tweaked alittle before diving into the bumper cover. You can see how high off the parking lights it sits, as well as not being lined up with the headlight doors. It seems to me like the rear of the hood needs to be raised a bit. And if you look at the driver's side rear part of the hood, it looks like its sitting alittle below the fender. Ide try to raise that rear corner, which should in turn lower the nose of the hood.
Has the car ever had its fenders or bumper cover removed or repaired? How about the headlight assemblies? if everything is undistrubed for the most part, and things were lined up nice before, Ide say just keep messing with that hood until she looks good.
J.
Old Feb 9, 2009 | 08:33 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Don't forget to adjust the little black plastic bumpers into the hood as your lowering the latch, otherwise it will sit odd. There should be one in the back of the hood too by the firewall. Otherwise from the different of parking lights to headlight alightment, i would guess the bumper was sagging a 1/2 an inch or so like the rest of the guys above.
Old Feb 9, 2009 | 09:41 PM
Car: 91 formula
J.
i did replace the driver side fender but the hood was always like this. before i put the formula hood on the gta hood was perfect flush to the bumper. I need one of you to put a pick up and show me what your talking about please. Im having trouble understanding. you say the bumper is sagging put what bracket should i look at and were. thanks
Old Feb 10, 2009 | 12:34 AM
HCR13's Avatar
Car: 1987 Trans Am
yeah, on second thought, try lowering the latch. The latch mechanism is held in place by 2 bolts and if you loosen them up, the latch can be moved up and down and the latch decides the final resting place of the hood...
Old Feb 10, 2009 | 06:53 AM
Car: 86 Trans AM
Yeah as soon as I clicked back onto this thread, i realized I forgot to say something about the latch. I would definetly try lowering that too see what happens.
And as the other guy said...there are bump stops at the back corners that are basically bolts with rubber bumpers on them. They hit the hinges, not the hood. You'll see em.
J.
Old Feb 10, 2009 | 11:17 PM
Car: 91 formula
alright guys I will try to lower the hatch ASAP and post results up soon. Its going to be hard working with my broken finger. I will make my brother do it LOL
Old Feb 10, 2009 | 11:52 PM
popballz's Avatar
Car: 89 firebird
i had the same problem, expect mine was probably worse
i moved the latch ALL the way down, and loosened the bolts on the top of the bumper on that bracket and pulled the bumper up and tightened them.
and mine is still a little too high
oh ya, and my hood was all messed up like that AFTER i paid a body shop to adjust it, lol
mine went from this
to this
by doing what i said above, hope it helps
Old Feb 11, 2009 | 06:40 AM
Car: 86 Trans AM
Yours looks like it would benefit from some headlight door alignment. As for the bumper cover area, is that an aftermarket bumper? Looks like alittle bit of nose sag starting. Still, that doesnt look too bad. From a different angle I bet its harder to see...and most poeple wouldnt notice unless you pointed it out.
Lining up body panels on these cars gives me nightmares. haha. Too many parts and panels and shims and...ugh. haha.
J.
Old Feb 11, 2009 | 09:58 AM
popballz's Avatar
Car: 89 firebird
J.
was this for me?
it shouldn't be aftermarket, but idk what happened before i got it...
and you know how to adjust those headlights?
Old Feb 11, 2009 | 12:35 PM
Car: 86 Trans AM
The headlights have brackets...and the brackets are bolted to the headlight assembly. So there are little tweaks you can make to the light. Also, the headlight door cover itself is bolted on, and you might be able to shift it alittle....i cant remember. I dont think you can do much with the cover. But the entire assembly can be shifted around a good bit from what i can remember.
J.
Old Feb 12, 2009 | 05:12 PM
Car: 91 formula
well Im back with some update pictures. its looks a hundred times better. thank you all that responded to this thread. It looks sharp. the headlight are sticking out alittle i notice now. but that will be my next project easy fix.
Attached Thumbnails formula hood on gta  it not a proper fit look.-good-lining-020.jpg   formula hood on gta  it not a proper fit look.-good-lining-016.jpg
Old Feb 13, 2009 | 11:45 AM
IROCKET4U's Avatar
Car: 1988 IROC
Engine: 5.7 litre
Transmission: Auto--700R4
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
What exactly did you do to get the hood corrected? Adjust the latch? Bumpers? I have a similar problem on a car I just bought. Also my hood gaps arent even. On the drivers side my hood is in contact with the fender up close to the windshield. Further down the hood the gap widens. What is the easiest way to center the hood?
My hood has a dent in it at the front which Im sure isnt helping matters but it shouldnt be sticking out the way it is.
Old Feb 13, 2009 | 06:47 PM
popballz's Avatar
Car: 89 firebird
Originally Posted by IROCKET4U
Also my hood gaps aren't even. On the drivers side my hood is in contact with the fender up close to the windshield. Further down the hood the gap widens. What is the easiest way to center the hood?
My hood has a dent in it at the front which I'm sure isn't helping matters but it shouldnt be sticking out the way it is.
to line up the hood you gotta move the hinges
moving the hinge a little back will make the front come a little closer to the fender and moving it a little forward will make it go a little away from the fender
when i did mine, i got it in the right position, then barley loosened the hinge and hit it with a hammer, this way you know your only moving it a little bit!
all i did was lower the latch all the way down.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Randomtask2
Aug 13, 2015 01:57 AM
bryan623
Aug 10, 2015 11:33 AM
