Help me clean up my '92 Z28..
Old Mar 5, 2009 | 06:15 AM
Gr89RS's Avatar
Car: '02 Z06
My '92 Z28 I just purchased has a gap between the hood and the top of the front bumper that's about 1/2" bigger than it should be. The bump stops under the hood are adjust all the way to their lowest point, can't think of any other way to close this gap up? Almost thought about a coil off the metal spring on the underside of the hood to make the gap go away...but I'm not sure how that will work out lol.
Any suggestions?
Old Mar 5, 2009 | 07:18 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Help me clean up my '92 Z28..
the hood latch adjusts down
at the top of the bumper inside the engine compartment there is several bolts you have to loosen up and pull the bumper cover up
Old Mar 5, 2009 | 04:33 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
If you need help I can show you, Im in santa ana.. but there are bolts that have to be loosened underneath the cover. It usually has nothing to with the hood. I actually did mine a couple days ago
Old Mar 5, 2009 | 06:13 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
Loosen the two 13mm bolts that hold the hood latch on and move it down. If you need more downward movement loosen the the latch mounting panel and move that down. There really isnt that much movement in the bumper cover brackets themselves, sounds to me that its more in the latch. How does the hood pop when you pull the handle. Does it pop up or does it just kinda lift a little and is tough to open. A properly adjusted hood should have a pretty good pop to it when the handle is pulled.
Old Mar 5, 2009 | 06:44 PM
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
there is a ton of movement on the bumper brackets, I havent killed my short term memory that bad. I dicked around with the hood forever and it created more problems. Moving the latch down is what makes the hood not pop up.
Old Mar 6, 2009 | 12:39 AM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Any suggestions?
Cutting the spring isn't going to make anything better. If the hood is sitting flush with the tops of the fenders in the front, then the latch is probably in the right spot. Still I'd first look at the hood latch as a simple adjustment, but most often hood latches don't move, bumpers get "bumped" and that can knock things out of alignment. Fortunately there is some adjustment built in to the bumpers.
Old Mar 7, 2009 | 07:52 AM
Gr89RS's Avatar
Car: '02 Z06
Thanks everyone! Used a lil of each of your suggestions and it minimized the gap just how I wanted. Thanks again!
Old Mar 9, 2009 | 06:17 AM
jamon8's Avatar
Engine: 350 tpi
show some before and after pics and how you ended up doing it so others can get a feel of how to do it
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
WhteRbt
Sep 21, 2015 09:48 AM
