i have a huge proble (did a search nothing helped)
Old Apr 5, 2009 | 09:11 PM
ILUVMY89's Avatar
i have a 89 camaro that had the mount for the trunk lock removed im talking about the mounting bracket thats tack welded to the frame that the trunk lock bolts up too now i got a new mount out of a 89 and the lock out of a 91 and they dont match up the holes are different i need help fast i cant just be driving araound and everytime i hit a bhump my hatch jumps open thanks alot in advance
Old Apr 5, 2009 | 09:48 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: i have a huge proble (did a search nothing helped)
Sound to me like you need to get a latch from an 89 that will fit your new bracket. I don't really know what else we can do for you.
I could wiggle my nose and wave my magic wand but I've been told that doesn't work long distance.
Old Apr 5, 2009 | 09:49 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
i believe the hatch motors were diff for those 2 years...
Old Apr 5, 2009 | 09:58 PM
jagass's Avatar
Why the hell it doesn't fit?...
Old Apr 5, 2009 | 10:26 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
man if you can put those doors on you sure should not have a problem with a trunk.
nice ride - very nice ride.
at time you have to stick with what you have when it comes to things like trunk hatches.
Old Apr 5, 2009 | 10:47 PM
ILUVMY89's Avatar
i tried to drill holes in the bracket but i think im just gonna go look for another trunk lock at the junkyards i cant find any anywere else for a 89 specifically
Old Apr 6, 2009 | 01:08 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Any 1986-early 91 pull-down unit will work for you. Here's how to easily tell. Those years of pull-down unit have a metal frame where it bolts to the bracket on the car with 3 screws. You can't use the late 91-92 style that has a tan-colored plastic frame that bolts to the bracket.
Lon
Old Apr 6, 2009 | 01:32 AM
ILUVMY89's Avatar
here are the pics of wat im dealing with
lock with pull down that doesnt fit or work i guess the people welded the bracket so it would just shut instead of buying a new motor
and here you can see how it doesnt line up at all
Old Apr 6, 2009 | 08:12 AM
lonsal's Avatar
The purple mount is for a late 91-92. The pull-down unit you have is the earlier style. You'll need to either cut out the purple mounting piece and get the correct 86-early 91 style or get a late 91-92 pull-down unit and hatch hook. The wiring is different for each style too.
Here's what a late 91-92 pull-down unit looks like:
Lon Salgren
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
Bstrang6
Aug 26, 2015 11:39 AM
JFry
Aug 19, 2015 01:25 PM
z28addict8490
Aug 7, 2015 08:48 PM
