275 40 17
Old Apr 15, 2009 | 11:29 AM
usacamaro's Avatar
Car: 92 rs & 89rs
Transmission: auto & t5
275 40 17
hi all i am running 93-94 firehawk rims they are 17 by 8.5 with 6.5 bs i have 2" spacer all the way around with 275/40/17 on all four corners i know the front is rubbing at full lock and probaly the only to fix that is to run 245/45/17 up front but that will have to wait .the rear tires are rubbing when i hit a bump on the front edge of the finder lip . the car is all stock with 250000 miles on it so i know the springs are worn but it is not loweredjust lowered by worn springs. i wanted to lower it with the intrax springs 2" drop but they are rubbing now it will probaly be wrose if i lower it .i heard of people rollin the fender lip to help but i cant find out how they did it is this the only to fix this problem or is there anything else i could . any help with this would be much appriceted
Old Apr 15, 2009 | 11:48 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: 275 40 17
Originally Posted by usacamaro
hi all i am running 93-94 firehawk rims .... with 275/40/17 on all four corners i know the front is rubbing at full lock and probaly the only to fix that is to run 245/45/17 up front
You do know a 45 series sidewall is even taller than a 40 right ? Did you mean 275/35-17 ?
The Ronal R-15s run a 275/40-17 tire with no issue.
How many times in daily driving are your turning full lock anyways ?
If rubbing is an issue, common sense would say to not turn the wheel to full lock anyways.... even if rubbing wasn't a problem... full lock is rather rough on the PS pump anyways.
Old Apr 16, 2009 | 10:09 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: 275 40 17
a 45 is not always taller then a 40 a 245 45 17 is actually a tiny bit shorter than a 274 40 17 . the 45 is a % of the width which is narrorow than the 275. but when i am backing out of my drive way or something like that it rubbs i heard of people running the same tires with no problem but i still rub. i will sooner or later change the front to the 245s but i want to keep the 275 on the rear love the look but i dont want the fenders to cut the tires all up . i know it is probally because my springs are sagging but i hear some people run the same tires and lower there cars with no rubbing and i dont know what to do but mabe roll the lip but cant find out how .
Old Apr 17, 2009 | 12:06 AM
deadbird's Avatar
Engine: TPI 305/ v6
Re: 275 40 17
Actually, I fully understand how the ratio works.
The problem is I was to stupid to see you stated the change of > 245 < /45-17
Old Apr 17, 2009 | 12:09 AM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: 275 40 17
no problem you wouldnt know about the rear
Old Apr 17, 2009 | 12:27 AM
Stephen's Avatar
Car: 87 GTA
Re: 275 40 17
The problem is your 2" spacers.
I run 17" 275/40s front, 285/40s rear with zero rubbing issues, not even at full lock. And both sizes on direct fit, no spacers needed, 4.5" BS, 17" x 9" wheels.
I think your spacers shoulda been a little smaller.
Old Apr 17, 2009 | 11:56 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: 275 40 17
the rims are 17 by 8.5 with 6.5 bs i seen other people on here with the same size and they said they used 2" spacers thats why i ordered them i figured if they were a qutar inch smaller that might work but not sure if the front would rub even more or if even they sell that size only ones i seen were 1 and a half or 2" not three qutars
Old Apr 18, 2009 | 12:01 AM
Stephen's Avatar
Car: 87 GTA
Re: 275 40 17
Correction....I didn't notice the width first.
If they don't sell them in 1/4" increments, you could always have 2" ones turned down to 1.75" (or whatever) at a local CNC shop.
Old Apr 18, 2009 | 01:24 AM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
Re: 275 40 17
I think the issue may be that he is running newer wheels than what the Ronals are?
The ones he has are 4th Gen wheels.
1986Z28OWNER
Dec 13, 2015 10:19 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
89Irocn2o
Mar 8, 2001 10:00 AM
