best way to fix battery tray and bottom of radiator support
Car: 1989 Iroc Camaro
Engine: Stock 350 TPI
Ive have found replacement battery trays and the bottom piece of the radiator support for cars. I know that having them welded in would probably be the best way. Just wondering if anybody out there has tried some of that norton speed grip adhesive or the 3m stuff to anything like that on them. If worked and held up. if it was faster and better or if i should just stick to welding them.
Car: 1989 Firebird
Engine: 5.7 LS1
Re: best way to fix battery tray and bottom of radiator support
Don't know for certain but the H2SO4 (acid) from the battery that causes the rust would probably adversly effect any adheasive. I would weld, or if you are set on adheasive atleast use rivets to add to it incase the adheasive broke down.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
dont glue them in, that just a horrible idea.
Welding is the only way to do this right
may i ask where you found replacement battery trays?
classic industries sells them and i believe ecklers sells them also
Car: 1986 Camaro z28
Engine: 350 v8
your best bet is what i did. Cut the old tray out and fill the void with sheet metal, weld it in place properly. i actually found a battery tray that will bolt in from a chevy car and used that. It looks better now than before
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Which side is your battery tray (passenger or driver)? And how bad is the rust? Got a pic? If its just in the center of the tray, and your tray is on the passenger side, you could always cut some more away and pop in a 4th gen overflow/battery tray. You could ditch your stock, probably cruddy, overflow and solve your rusty tray problem in one shot.
Otherwise...cut cut cut cut until there is no more rust and weld in some new metal. Thats the only way in my opinion.
J.
J.
Car: 92 rs & 89rs
Transmission: auto & t5
how much of the battery tray do you have to cut out to put the 4th gen one in do you have a pic mine is very rusty and would like to do this to mine
Car: 86 Trans AM
Haha not quite that much. You might be able to get a bite on some solid metal to bolt it in. Otherwise, you could get rid of all the rust, then add some metal to bolt the battery tray to. But from the looks of it, you are going to have to do a lot of removing and replacing to have good metal.
Best pic I have... There is one bolt that holds the tray down. Then the battery hold down holds the battery and also secures the tray. No pictures of the actual hole unfortunatly.
J.
J.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Apr 30, 2019 12:14 PM
db057
Aug 11, 2015 10:11 PM
