1990 iroc hatch back not closing
Old May 20, 2009 | 09:13 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
I thought I posted this before but cant find the answer. Can anyone tell me how to close the rear hatchback 1990 iroc I tryed hooking up battery cables but no luck maybe the wire is bad or syl noid is bad I want to manual close if there is a way. Thanks
Old May 23, 2009 | 08:56 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Re: 1990 iroc hatch back not closing
lol like I thought no way to do it or no information on how
Old May 23, 2009 | 08:58 PM
r62mcmahon's Avatar
Car: 1989 IROC
Axle/Gears: BORG WARNER /3:70
you can slam it but it will crack the housing for the pull down motor
Old May 23, 2009 | 09:08 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
yea I thought about slamming it shut but I,m trying to restore this car not cause more damage
Old May 23, 2009 | 09:20 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
once i used a screw driver and pushed the release where the hatch goes - and another time i pushed down on the inside of the mechanism and it unlocked the unit so that the bar in the hood would be accepted in the latch mechanism.
another time i pulled the unit out - cleaned it with gun scrub - then used gun lube - the kind you can see actually be absorbed into the metal - did that 4 or 5 times - them used some artificial lube - and put it back in and it worked.
dont really know what i did to make it work.
Old May 23, 2009 | 09:33 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Well your comment sure is alot of help If your in an emergency situation just remove the pull down and tie it shut until you can figure out what is actually wrong.
Old May 23, 2009 | 09:46 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Ok thanks for the ideas hope to get this done before to much rain gets in looks like a tropical storm down here in the south
Old May 26, 2009 | 09:13 AM
1Aauto's Avatar
Former Sponsor
Dusty if you need a new pull down motor we sell them.Here's a link to them.
Camaro Hatch Pull Down
Tony
Old May 26, 2009 | 09:21 AM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
It's sounds like you may need need a new hatch motor assembly. If you do, we have them available on our website.
Old May 26, 2009 | 08:45 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Ok thanks again for info right now I have it tye wrapped shut , should I find the hatch assembly is bad I will be getting in touch
Old Jun 6, 2009 | 09:32 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Update on hatch back I moved the hold down assembly up about a 1/4 inch tightened it up and removed the thing that has 3 little magnets? The hatch closes tight now I will relace and relocate parts to orig place once I get the wiring fixed The key I got with car had chip missing so it wont crank anyway
Frozer!!!
Jan 19, 2024 04:55 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
mustangman65_79
Aug 11, 2015 03:17 PM
