IROC hood louvers - broken posts
Old Jul 12, 2009 | 11:15 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I came across some IROC hood louvers but some of the posts that connect it to the hood are broken or missing. Is there a way to repair them, or still use it without them?
Old Jul 12, 2009 | 11:57 AM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: IROC hood louvers - broken posts
Here is what I did, plus there are some more good ideas out there.
https://www.thirdgen.org/forums/body...ting-stud.html
Old Jul 12, 2009 | 12:18 PM
Scorpner's Avatar
Engine: V6, V8
I was thinking of something like that but wasn't sure how well it would hold up. That's probably what I'll do then.
I did do a quick search but didn't find anything. I'll look around again to see what other ideas are out there.
Thanks!
Old Jul 12, 2009 | 12:42 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
When I did the repair they held great, just make sure to use the right kind of epoxy and use it generously.
Old Jul 12, 2009 | 02:22 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
couldn't you just use 3M double sided body tape to put them on? Much easier than ****in around with epoxy...
Old Jul 12, 2009 | 05:30 PM
Scorpner's Avatar
Engine: V6, V8
That's a good idea too, but wouldn't it be difficult to remove them later to repaint or something?
Old Jul 12, 2009 | 05:32 PM
Scorpner's Avatar
Engine: V6, V8
Do you happen to remember what you used?
Old Jul 12, 2009 | 06:00 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I don't remember but I bought it at True Value, iirc it was for adhering metal to plastic.
Old Jul 12, 2009 | 07:13 PM
Scorpner's Avatar
Engine: V6, V8
Close enough for me to find something similar, I appreciate the help.
Old Jul 12, 2009 | 07:34 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
It's an easy fix and imho you will be better of with this method than using double stick tape. I'd hate to see you blasting down the highway and see a louver fly off because the tape failed
Old Jul 12, 2009 | 09:00 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There is no flat surface to the undersides, so I'd be weary of the tape as well.
Someone told me a superglue trick that I've yet to try. Adding baking soda to the superglue is supposed to make an instant bond - just glue pieces in place and sprinkle the baking soda on the wet glue. Supposed to work really well for places where your gluing 1 piece to another at 90 degree angles - glue both pieces, then run a bead along the inside corner and sprinkle the baking soda for an instant 'weld'.
Old Jul 13, 2009 | 05:39 AM
Scorpner's Avatar
Engine: V6, V8
Thanks, I've never heard of that before. I might try that in the future, but I'll probably stick with the epoxy for this since it's been used before.
Old Jul 13, 2009 | 08:47 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I used the body shops U/V resistant windshield urethane. It WILL NOT come off lol.
Frozer!!!
Jan 19, 2024 04:55 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
