How do i change the headlights?
Old Aug 14, 2009 | 09:14 PM
fishguy88's Avatar
This is most likely a dumb question but i cant figure out how to take the headlights out of my 1991 camaro. Does the bumper cover have to come off?
Old Aug 14, 2009 | 09:33 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: How do i change the headlights?
Take off the black trim that will expose the screws for the lights IIRC.
Old Aug 14, 2009 | 10:21 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
The bumper cover will flex out of the way, just be careful not to pinch it too much or chip the paint or something. A thin shaft screw driver helps just make sure the Philips head is the right size or it might strip out the inside. Otherwise you can try tilting it with the adjustment screws to gain better access.
I've completely removed mine to paint without touching the bumper cover.
Old Aug 15, 2009 | 07:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Use a strip or two of tape under the lamps to protect the paint.
JamesC
Old Aug 16, 2009 | 08:07 PM
fishguy88's Avatar
Thanks everyone i got it now. Do you think gm engineers could of came up with a better way to change light bulbs. I wonder how many people have scratched the hell out of their cars trying to figure this out.
Old Aug 16, 2009 | 08:19 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
GM did that so you would take it do the dealer for a $30 headlight and $50 labor to install it
but now you know how to and can even put a set of silverstar headlights in for cheaper than the dealer
Old Aug 16, 2009 | 08:45 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I just changed the headlights in my iroc, and I can't seem to access the side to side adjustment screw.
Old Aug 20, 2009 | 12:32 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
to avoid headaches and a lot of swearing, I would only loosen up the lower screws half way or so while undoing the top ones all the way. It should allow you to be able to slide the bulb out without removing the entire bezel. No parts falling, no screws disappearing, no throwing tool in anger
Old Aug 20, 2009 | 05:52 PM
89RS_82Z's Avatar
i forgot to say that, thats exactly what i do
GTAman
Mar 15, 2019 11:40 AM
rh76camaro
Exterior Parts for Sale
Aug 29, 2015 06:53 AM
Fronzizzle
Aug 19, 2015 01:36 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
