Switching T-Tops from Lexan to Glass
Old Sep 11, 2009 | 11:00 AM
robster66's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 305 T.B.I.
Axle/Gears: 2.73 Open Diff
I tried searching on the forum and I couldn't find anything. The glass T-Tops do not fit and I tried adjusting them. I was trying to find something that showed how to put the whole setup from lexan onto glass so they will fit and I can use the same key.. Any ideas?
Old Sep 11, 2009 | 11:35 AM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Re: Switching T-Tops from Lexan to Glass
There's no reason why you can't replace your Lexan tops with glass ones. Why aren't they fitting? Do they not latch correctly? As long as you have tops with the pin style latch you should be able to make them work with some adjustment.
Also, it's very easy to swap lock cylinders so you can keep your existing key. All you need to do is remove the black inner trim piece and you'll see the lock cylinders. They are held in place with a clip from the back side. All you need to do is remove the clip and swap the cylinders.
Old Sep 11, 2009 | 11:52 AM
robster66's Avatar
Engine: 305 T.B.I.
Someone told me I had to caulk the whole setup to the glass ones using glass caulk. They are both pins but I could not get them to fit. The lexan ones fit fine.
Old Sep 11, 2009 | 11:59 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
The mounts inside the body are adjustable or can even be replaced. I thought someone just posted something similar?
Old Sep 19, 2009 | 02:29 AM
kittca's Avatar
92 firebird, I replaced my lexan with glass, with a few minor adjustments.
Old Sep 22, 2009 | 10:18 AM
CAL101291LANI's Avatar
Car: 1987 Trans Am. 1992 Firebird, F-150
Engine: 305 efi, 305 tb
Transmission: 5 spd., auto
Axle/Gears: idk..
I have a 92 firebird and an 87 trans am. the trans am has glass and the forebird has lexan. When I was cleaning the firebird the other day I tried to put the glass tops on the firebird and discovered the pins on both t-top's are different. the glass has a small metal pin, and the lexan has a metal pin with a large plastic cover over it. Im guessing you could just swap out the pins, or the mounts on the car.
Old Sep 22, 2009 | 10:45 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Yes, you can just swap the pins.
When I got my 92 Camaro, the PO had 2 sets of tops, one glass and one lexan. They both fit just fine, no changes needed to swap between them. I sold the glass ones because they were heavier and I didn't want to risk my wife dropping them while taking them off.
Now I kinda wish I had kept them as they were the nicer of the 2 sets.
Old Sep 25, 2009 | 11:24 AM
robster66's Avatar
Engine: 305 T.B.I.
I swapped the pins but on the ttops I took most the weatherstripping off and tried spraying them with water. It leaks but not bad. I had to drill holes in the glass ones to make the bigger pins from the lexan ones work but it wasn't to bad.
Old Apr 2, 2013 | 12:34 AM
gio.cortes89's Avatar
Car: 92 firebird
Engine: v6 mpi
what adjustments did u end up doing? i ended up switching the lock cylinders however now im in the process of making the holes bigger on the glass ttops so the large pins can go through..what adjustment did u do?
Old Apr 2, 2013 | 12:35 AM
Car: 92 firebird
Engine: v6 mpi
which mounts? i have a 92 firebird and my older bro has an 88 trans am and the mounts on the body are the same and his glass tops are the same ones i have now
Old Apr 2, 2013 | 05:18 AM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
gio, you will need to remove some of the interior trim and adjust the mounts where the top pins fit into to get the tops fitting correctly. As for drilling out the holes for the pins you should have been able to swap the entire lock assembly from the lexan tops to the glass tops.
Old Apr 2, 2013 | 07:53 AM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
When I did this switch on my '91 I swapped the pins and made a few adjustments to the mount on the car. A little tedious, but nothing hard.
Old Apr 2, 2013 | 07:15 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
i swapped from lexan to glass on my 92. not hard. i took the lexan latches and swapped them over to my glass ones from an 87. i used a 3/4 bit to make the hole bigger for the large pin.
Old Apr 2, 2013 | 07:24 PM
Car: 92 firebird
Engine: v6 mpi
well i did the whole switching out the assembly from lexan to glass so hopefully i dont have to adjust the mounts..but i looked at the mounts and how does one adjust it? like i know i have to remove the trim and all but i guess my question would be why would i adjust them if the large pins already went through with no problem when they were on the lexan top? i assume the lexan and glass are same size with diff pins so i use the correct pins(aka large) then i shouldnt have to adjust the mount, right?
Old Apr 2, 2013 | 07:50 PM
Car: 1984 T/A
Engine: LQ4
I had to adjust mine. depending on the state of your weatherstripping it may need to be adjust. when i first put my glass ones on there was a gap. i adjusted it and now its tight.
64goatman
Sep 9, 2015 01:09 PM
383cam
Sep 9, 2015 06:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
luvofjah
Sep 3, 2015 07:08 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
