T-Top key?
Old Dec 5, 2009 | 09:23 PM
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
T-Top key?
i just bought an 1988 Camaro IrocZ and the original owner lost the key to the T-tops. how can i go about getting a new 1 :x. I don't think a locksmith can make 1 without having the original or a copy of it. and atm i cant take the tops off w/o the key so i couldnt even bring the ttop in for a moulding.
Any ideas? i saw on ecklers i can buy new locks w/ keys but i don't wanna spend 54$ each when there may be another way.
Thanks,
Sean
p.s. if you got any ideas please say what it prolly would cost so i can weigh my options.
Old Dec 5, 2009 | 09:37 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
Re: T-Top key?
if there is a good locksmith in the area, they CAN make you a key without one to copy. I get it done all the time for the tow yard i work at.
Old Dec 5, 2009 | 09:48 PM
Slash's Avatar
Re: T-Top key?
watcha think it would cost for that since there aint no key. And would he have to like inspect the lock or something.
Old Dec 5, 2009 | 11:13 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
Re: T-Top key?
it depends, if those are the origional tops to the car they can cut a key from the vin number in about 5 seconds. we used to use a guy that would do a series of test fits and cuts and have a key in about 15 minutes. your in ny so i cant vouch for the cost, its usually about $50 for use, but we have used our locksmith for years. go down to a locksmith shop and see what they can do. you said you cant get the tops off to its going to be a royal P.I.T.A to get the locks out without damaging anything
Old Dec 6, 2009 | 12:43 AM
oscarsrs's Avatar
Car: 91 RS/ QX56/Altima 3.5 SE
Transmission: AUTO
Axle/Gears: ?
Re: T-Top key?
Thanks,
Sean
i thought the ttops,trunk,doors and rear glove box had same key ? mine does...
Old Dec 6, 2009 | 12:57 AM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
Re: T-Top key?
normally they do, but if your like me, youve changed all those haha
Old Dec 6, 2009 | 09:10 PM
Slash's Avatar
Re: T-Top key?
the ttops arnt the originals.
the owner before me was dumb and forgot to lock ttops down 4-5 times causing him to need 4-5 new sets lol. and now this key for them are gone.
Old Dec 6, 2009 | 09:18 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Re: T-Top key?
I see t-tops on craigslist constantly
Old Dec 7, 2009 | 03:17 AM
popballz's Avatar
Car: 89 firebird
Re: T-Top key?
Take the plastic cover off the inside of the t-top.
I think its only like 3 screws.
The locks pop right out, just a little clip holds them in there.
Then replace the locks or take to a locksmith to get a key cut.
(you could also just leave the locks out, you do not need the lock, then it is easy to get in your car when you lock the keys inside. )
Old Dec 7, 2009 | 02:15 PM
Slash's Avatar
Re: T-Top key?
ty
i'l prolly just bring em to a locksmith and get keys made. definately gonna b cheaper than to buy the whole new locks ( 54$ each ttop on ecklers )
Old Dec 7, 2009 | 07:12 PM
Parmetta's Avatar
Car: 92 RS
Engine: 305 TBI
Transmission: auto
Re: T-Top key?
I just bought replacement t-tops for my 92 RS. Can i just pop out my original locks and replace the 'locked' ones on my 'new' t-tops?
Is it just this easy?
remove 3 screws
take off panel
pop clips
remove lock
Old Dec 7, 2009 | 08:15 PM
87_Injected's Avatar
Car: 2010 2LT RS
Re: T-Top key?
I need to do this myself. Hate to have the tops blow off on the hwy, yet alone being stolen!
Old Dec 7, 2009 | 08:27 PM
Parmetta's Avatar
Car: 92 RS
Engine: 305 TBI
Transmission: auto
Re: T-Top key?
My drivers side is Lexan and is bowed in the middle. Its actually quieter at 75 mph with the tops out than it is with them in. My replacements are glass and don't have the million little starbursts like the pexiglass originals have. I can actually see thru them. lol
Old Dec 7, 2009 | 09:24 PM
Slash's Avatar
Re: T-Top key?
sadly thats what the last owner did with my camaro. he would step on the gas and the ttops would blow right off b/c he never locked them down. so now this is about the 4th pair on the car and i got no key to go to them
Old Dec 8, 2009 | 01:37 AM
popballz's Avatar
Car: 89 firebird
Re: T-Top key?
remove 3 screws
take off panel
pop clips
remove lock
yea, its easy.
like lock the lever in place?!?! I barley ever use the key and lock and never had a problem.
Old Dec 8, 2009 | 02:14 AM
Motopsyco's Avatar
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
Re: T-Top key?
Ok something I dont get here is them possibly blowing off, there is a lever that pretty much locks them in place and a key wich litterally locks them in place, there is no way that they can blow off driving down the highway if your levers are intact, and no one can simply break in and steal them if you have your doors locked, so if you can lock your doors, then I wouldnt worry about the t-top locks, theres no way someone can remove them and steal anything from there unless you keep your doors unlocked
Old Dec 8, 2009 | 01:42 PM
Slash's Avatar
Re: T-Top key?
last owner forgot to lock the lever a few times causing them to blow off.. he was an idiot basically
Old Dec 8, 2009 | 02:21 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: T-Top key?
I locked my keys in the car a while back, i had push down the window a 1/2inch and slide my finger in there to unlatch the t-top. locks are good, one time i taped clothes-hangers and had to slid in through a lil opening from the window and used the clothes-hanger to puch the unlock button on the opposite side, power locks.
Old Dec 8, 2009 | 02:29 PM
Slash's Avatar
Re: T-Top key?
lol very innovative.
Old Dec 8, 2009 | 05:05 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Re: T-Top key?
I did that once but I just used a wooden yardstick through the passenger window seal to push on the hatch release button.
Didn't even hurt the seal....
Old Dec 8, 2009 | 06:35 PM
anthony714's Avatar
Re: T-Top key?
i had my t top keys made to match the ignition. i wanted all the locks th same and it wasnt cheap. if you dont care if the keys match pop you lock cylinders out like stated previoulsy. unscrew the plastic and there s a few screws and possibly a few pop rivets if i recall right. then theres the big spring type clip like the one that holds your door lock cylinder in place. as a matter of fact the cylinders are similiar. anyways once out you can then unlatch your t tops if you need to remove them since the ont be locked anymore. thennnnnnnnnnnnnn go to ebay,third gen ranch,etc and buy a replacement used set of t top locks fo rabout 10 bucks,get a spare key made at home depot for 2 bucks and you have locking t tops with keys!!!!!!!!
Old Dec 9, 2009 | 12:37 PM
Slash's Avatar
Re: T-Top key?
lol i jimmy'd the ttop locks w/ a screw driver last night and somehow they unlocked lol so now imma guess they're broken now but the lever still works. cant rly do much atm blizzard and it's stuck in the garage.
Old Dec 9, 2009 | 02:51 PM
Car: 1986 Trans Am
Engine: 5.0
Re: T-Top key?
You guys make me skeered. I want to install the stereo in my truck, into my T/A. Time to shop for a car alarm
*edit* Pain generators FTW!!!
Old Dec 9, 2009 | 03:16 PM
Slash's Avatar
Re: T-Top key?
lawl
Old Dec 9, 2009 | 08:20 PM
Parmetta's Avatar
Car: 92 RS
Engine: 305 TBI
Transmission: auto
Re: T-Top key?
[quote=popballz;4365806]yea, its easy.
I did the steps but i have no idea where to find the clips. my lock is rivited in position and everything else is rock solid. I have some pics of the locks i'll try to post tomorrow.
Am I overlooking them?
Old Dec 9, 2009 | 08:42 PM
Slash's Avatar
Re: T-Top key?
[quote=Parmetta;4367443]
yea, its easy.
i saw the same thing when i was trying to get my locks out. i jus ended up breaking the locks so now i can take ttops on and off and still have em in place via the lever. however i do probly plan on buying new ttops this spring most likely. they don't exactly match eachother >.>
Old Dec 10, 2009 | 05:54 AM
Parmetta's Avatar
Car: 92 RS
Engine: 305 TBI
Transmission: auto
Re: T-Top key?
[quote=Slash;4367466]
How did you 'break' the locks. I hate to damage the new tops, they are in excellent condition. I really would like to use my current locks to keep the car as close to original as possible. It always seems to be something odd to deal with
Here are pics of my locks
Don't think the pics will work. This is a difficult forum to post. maybe easier to draw pictures than post.
Last edited by Parmetta; Dec 10, 2009 at 11:15 AM. Reason: Fix'd pictures so they display
Old Jul 17, 2012 | 04:00 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
Re: T-Top key?
hmm my ttop lock is very differently shaped then my other keyholes i mean it kinda goes like /\/\ and i doubt i can get one made, these are the original ttops in my 84 though, the vin was etched in the glass from either factory or dealer
Old Jul 17, 2012 | 09:01 PM
82tarecaro's Avatar
Re: T-Top key?
Take the cylinders out, bring them to a locksmith and give him your door key. He can rekey the lock to that key. It should cost you 10 - 15 bucks per cylinder. Then you won't have 3 keys to your car.
Old Jul 17, 2012 | 10:26 PM
kmcn47's Avatar
Transmission: 5spd
Re: T-Top key?
how much would a new key be from say a dealer or a locksmith if i give him my vin?
Old Apr 19, 2019 | 04:34 PM
Locotrucker's Avatar
Re: T-Top key?
But then it's easy for a thief to steal them
Old Oct 22, 2025 | 05:06 PM
kxdN6f##Nbb!XSZ's Avatar
Re: T-Top key?
remove 3 screws
take off panel
pop clips
remove lock
you forgot drill out the 2 rivots
Old Oct 23, 2025 | 11:18 AM
BURD's Avatar
Re: T-Top key?
So glad my sec Gen has no locks. Locks was a bad idea
I’d have a lock smith open the lock. AND NEVER USE.
Old Oct 23, 2025 | 11:20 AM
BURD's Avatar
Re: T-Top key?
finding a dealer that still has key blanks is the problem, all the dealers here threw everything old out.
panthanator1
Jul 21, 2011 03:18 PM
zachkuby87
Oct 24, 2010 01:07 AM
North
Fabrication
May 22, 2008 12:10 AM
MiZZiE
Jun 8, 2006 07:49 PM
warrior_91
Aug 23, 2003 03:40 PM
