T-top question
Old Feb 2, 2010 | 07:13 PM
92rsydney's Avatar
Engine: TBI 305
T-top question
Pretty straight-forward question.
Will a 1990 T-top fit onto a 1992 T-top camaro?
Cheers for any input,
Maxim
Old Feb 2, 2010 | 07:35 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: T-top question
I believe they will. Make sure they are the same size & the latch pins are the same also.
There were 2 types-- Cars & Concepts ( C & C ) and factory T- Tops.
C & C are a little smaller than factory tops.
There were also 2 materials-- ( 1 ) Lexan ( 2 ) glass.
As long as they fit the opening & the pins are the same size, either Lexan or glass will work.
Old Feb 2, 2010 | 08:52 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: T-top question
The 82 may have used hooks instead of pins. In that case you may want to get the hardware from the car body also.
Old Feb 3, 2010 | 02:54 PM
Car: '87 Camaro
Re: T-top question
Thanks Al Hasse--
I've never seen that style--I just learned something else!!
Old Feb 3, 2010 | 04:04 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: T-top question
Hijacking time....
I want to find lexan t-tops for my base 1985, it has locking glass ones with pins/lever.
What years/models will have lexan ones that will fit?
Old Feb 3, 2010 | 07:36 PM
Car: '87 Camaro
Re: T-top question
For more info on years with lexan try
dave mc
He may have in stock
Old Feb 3, 2010 | 08:54 PM
madhatter's Avatar
Re: T-top question
Originally Posted by 3rd gen RS
Hijacking time....
doesnt matter. that is as long as they arent cc tops which are pretty rare ie you most likely find them. The glass and lexan are the same size with the only differences being the pins. you can swap the ones from your glass tops if they are the wrong pins in about five minutes. i wouldnt worry about it.
Old Feb 3, 2010 | 09:44 PM
Engine: 3.8, 3.4
Re: T-top question
Thanks, good to know, any idea how much the weight savings/difference is by chance?
Old Feb 3, 2010 | 10:09 PM
Drew's Avatar
Re: T-top question
Actually, the weatherstripping changed a couple times. While the tops from one year might well fit another year, unless they're pretty close you may run into problems with the weatherstripping matching up.
Lexan ttops are much much much lighter then glass. You can handle them easily with one hand. They just get cracks inside the plastic that's visible from inside the car. If you don't mind that they aren't crystal clear, they're a nice upgrade. They also are tinted darker, so on sunny days the glare isn't as blinding.
Old Feb 3, 2010 | 10:44 PM
Engine: 3.8, 3.4
Re: T-top question
Yeah, it occurred to me that the weight savings would be nice for performance and ease of use.
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
Penultimo
Camaros Wanted
Aug 20, 2015 08:42 PM
qz6lwp
Aug 20, 2015 08:10 PM
redmaroz
Aug 16, 2015 11:40 PM
