Hatch is leaking (HELP)
Old Feb 26, 2010 | 04:14 PM
POPODYNAMO's Avatar
Car: 84 Camaro Z28
Engine: 305 HO
Transmission: 700-R4
Hello i have a camaro and i know that my hatch is leaking but idk where. i think it is under the plactic piece where the metal and the glass meet. is there supposed to be a rubber thing there because i have one on but idk if its bad or wat. so if u know how to fix it please tell thanks
Old Feb 26, 2010 | 04:46 PM
StealthElephant's Avatar
Car: 87' Iroc
Re: Hatch is leaking (HELP)
theres a gasket that runs around the entire hatch opening. if its ripped/worn it can leak.
Old Feb 26, 2010 | 04:50 PM
POPODYNAMO's Avatar
Car: 84 Camaro Z28
Engine: 305 HO
do u know where to get them
Old Feb 27, 2010 | 09:45 PM
upandcoming's Avatar
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
another thing I have had to do with some of my third gens. is take some clear silcone and put it on the outside where the bottom of the glass meets the top of the hatch metal....just my...good luck
Old Feb 27, 2010 | 09:59 PM
jj74sd455's Avatar
Car: 91 bird
Engine: 305 tbi
Transmission: 4 speed automatic
Axle/Gears: factory
found this answer for you;
The seal between the window and the hatch is worn. Any glass shop will reseal this.to do yourself buy a glass sealer or tar. remove inner hatch cover, there are I believe 4 bolts holding the window to the hatch. remove them. Have a large 4by4 holding up the hatch. Remove the hatch struts. Clean off old sealer under window an hatch. Reseal the hatch/window. Put the struts back and retighten all the bolts snug not too tight.
Old Feb 27, 2010 | 10:48 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
X2 I use guitar string to get them apart then used 3M window urethane I dont have the part # but if you need it I can get it
Old Feb 28, 2010 | 07:44 PM
POPODYNAMO's Avatar
Car: 84 Camaro Z28
Engine: 305 HO
Thanks to everyone ill try to seal it soon wish me luck
Old Feb 28, 2010 | 08:37 PM
Ethan91's Avatar
Car: 1991 Camaro Z28
Engine: 6.2L LS3 to come
Transmission: 4L60E LVL2 700rwhp
Be afraid, be very afraid . Yeah this is what will happen if you dont get that fixed. oh previous owners, how I hate you.
Old Feb 28, 2010 | 08:53 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
Well mines leaking too, but its because of this:
Ever since I put new struts in it doesn't seal right....I don't know what else to do.
Old Feb 28, 2010 | 08:55 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Plus the pull down motor doesn't work. Its unplugged right now, but the thing will never seal it up right anyhow so it just keeps running and running and running and I don't want it to drain the battery...
Old Feb 28, 2010 | 10:14 PM
Ethan91's Avatar
Are you sure you got the correct length of struts? If it latched fine before that then I think the struts are probably a little shorter.
Old Feb 28, 2010 | 10:28 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Thats what I've been told before, but I don't have the old struts to compare anymore, and I'll have to find somewhere to get them for cheap, $50 is what I paid for them last time.
And theres still the problem of the electric pull down...I've always had to slam mine.
Old Mar 1, 2010 | 12:49 PM
cdoyle's Avatar
x3
Mine was leaking from this exact spot, I always thought it was the weatherstripping leaking, but finally one day I took the plastic trim piece inside the car off, and watched the drip of water come right from those bolts.
Old Mar 1, 2010 | 12:50 PM
cdoyle's Avatar
You say the motor is always running? Check the switch on the motor, sounds like the switch might be broke and the motor doesn't know it's all the way up (or down).
Old Mar 1, 2010 | 07:56 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
I'm going to get it taken apart sometime this week and maybe take it out and service it, if I can't figure anything out then I'll take pics and post them here I guess...
I just found out that all 1990's weren't slam shut hatches and well I've always had to slam mine so I probably broke the motor or something.
Old Mar 1, 2010 | 08:09 PM
Samdweezel05's Avatar
Sealing the problem from the inside of the hatch is not the answer. The water will still sit between the glass and the hatch. even if you keep it from entering the car it is still causing a problem. It will rot the hatch over time.
Twin_Turbo's Avatar
Mine was leaking between the 2 steel sections w/ the glass sandwiched in between too. The factory sealing job was very poor. I got lucky in that there was only surface rust on the underside panel. I took it all apart and had that part powdercoated so it won't rust in the future. Definitely something to tackle right now.
This is where it leaks, past this window adhesive/sealant
The large black panel on the right is the piece from the underside
My solution will be to go apesh!t with the sealer on the back of the glass, sealing around the bolts too. Really don't want to do this again, prying the rear panel off the glass can be a real PITA.
Old Mar 1, 2010 | 08:19 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
The only reason it leaks is because the struts or whatever dont alloy it to seal correctly, it sounds like the doors open when you listen to the trunk, and it only leaks a few drops on the corners, well the passenger side corner because thats the worse of the two sides.
When I take it to the car wash, I have to be careful when I spray the tali lights and the hatch because I will shoot water into the trunk, under the hatch, above the weather stripping.
Its not leaking or rusting, I've had mine taken apart and I've seen the underside of the hatch with the plastic piece removed and its not getting wet, or rusting at all, the problem is completely caused by the struts or pull down motor not functioning properly. Not something else.
I've looking into it many times, I tore the hatch apart in the summer.
Old Mar 4, 2010 | 08:15 PM
POPODYNAMO's Avatar
Car: 84 Camaro Z28
Engine: 305 HO
The only prob with this is that i want to put my louvers back on
Old Mar 4, 2010 | 08:27 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Motor keeps running and running = broken gear nut.
http://www.top-downsolutions.com/pro...products_id=46
Lon
PurelyPMD
May 5, 2016 04:57 PM
punkmaster98
Sep 30, 2015 11:01 AM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
bubbaz28
Sep 18, 2015 02:09 PM
