Budget Paintjob...Tips???
Old Mar 13, 2010 | 02:48 PM
psp963's Avatar
Car: 1989 camaro rs
You can say im a handyman.
i been working on my 89 camaro RS.
I have done UNDERCOATING, RUST FIXES, AND SOME PRIMERING\PAINTING
I NEED HELP painting i want to remove everything to paint it all one solid color. =D
so...which sandpaper should i use to remove everything.?? i heard of 400grit??
HERE are PICTURES of the stages and the last one is how i want it 2 look. =D thx guys
-gota love third gens.
Size:  136.1 KB Name:  DSCN2683.jpg
Size:  37.4 KB Name:  DSC04089.jpg
Old Mar 13, 2010 | 04:01 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Budget Paintjob...Tips???
are you saying you want to sand it down to the metal? i wouldn't. i would go 220 on a D/A.
Old Mar 13, 2010 | 04:10 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
If you want a proper finish sand with 320-400 all by hand. Do the flat areas with a block sander. Palm sanders ,etc are for quick jobs and can leave nasty flaws personal preference really. Painting is not all that hard you can get really good results. Way back when I was looking at doing paint myself I found this site. His video is pretty good and worth the few bucks to download it. Some very good tips and even does a very nice finish in a carport check out the sample vid.
http://www.easypaintyourcar.com/
Old Mar 13, 2010 | 04:26 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
you want it to turn into a firebird?
sorry, couldn't help myself
ifor a total paint job, it really depends on what tooks you have at your disposal. Do you have a good compressor? a paint gun? were you planning on doing the whole job with rattle cans?
I've done both, give us some more details and I'll help you out
Old Mar 13, 2010 | 05:03 PM
psp963's Avatar
Car: 1989 camaro rs
THx 4 the help pals.
yeah haha into a firebird. =D yehhhhh righht
i have a craftsman compresor and a paint gun but never used it.
i have been doing everything by can all the time.
im thinking that satin black with 2 white stripes. so should i sand with 220?
Old Mar 13, 2010 | 05:12 PM
58mark's Avatar
400 would be better... I've seen surface scratches through paint with 220
sounds like you could get away with a single stage enamel. try TCPglobal for prices, they also sell through ebay
Old Mar 13, 2010 | 06:37 PM
psp963's Avatar
Car: 1989 camaro rs
yeah 400 sounds better. i jus had that question....i know how to take the side gfx off and lights BUT I REALLY need help taking off the front bumper...backbumper...and front 2 fenders....as soon as i know that ill be on my way =D
Old Mar 13, 2010 | 06:39 PM
58mark's Avatar
is there damage? for anything less than a ground up resto, you should paint them on the car
Old Mar 13, 2010 | 06:42 PM
58mark's Avatar
here's my car... I can paint with a gun, but I did this with rattle cans. I'm going to re-do it when I finish my impala restoration, and can take more time
https://www.thirdgen.org/forums/memb...en-family.html
Old Mar 13, 2010 | 06:43 PM
psp963's Avatar
Car: 1989 camaro rs
it has a little rust between the back plastic bumper and body.
and i want to remove the front as well to see hows evverything. mostly surface but o get at all the rust you have to remove it and all around it.
Old Mar 13, 2010 | 06:44 PM
58mark's Avatar
gotcha.... i hear the passenger fender is tricky because of the antenna. A GM service manual would probably be worth it's weight in gold to you
Old Mar 13, 2010 | 08:18 PM
i actually did my s10 with 180. i'm planning on painting my Z. i'm going to d/a with 180. then cover the car in filler primer, then block with 180, then block again with something finer.
Old Mar 15, 2010 | 06:18 PM
liz-o's Avatar
dude.... i work in a paint shop... and if you can, trust me.... you want to buy or find someone with a dual action sander. it will make it so much easier. plus, you want to start getting paint of with 80 grit, then 100, and work your way finer until there is fine tooth for paint to stick to.
Old Mar 15, 2010 | 06:47 PM
mister_hudson's Avatar
Car: '92 Z28 Convertible
Engine: 305ci TPI
Transmission: 700R4 shifted
Axle/Gears: 2.73 (for now)
I really don't intend on hijacking this thread but I am curious as to why you'd want to leave the GFX on when painting? I can understand the fenders but wouldn't it make a cleaner job if the GFX were removed, painted then replaced?
As I have been told time and time again -it's in the prep work! Every little imperfection will show through when you paint so get the body smooth and flawless before you start applying the base coat...
Old Mar 15, 2010 | 07:53 PM
58mark's Avatar
I was talking about the fenders, and to some extent the bumpers. I'm relaly not sure how easy the ground effects are to take off, but I've seen great paint jobs with them left on, so I know it's possible
Old Mar 15, 2010 | 08:33 PM
Engine: 305ci TPI
Ah! That makes sense - I agree with the statement that unless you're doing a FULL restoration there is no need to go through all of that. As far as the GFX I could see it going both ways - personally when I do mine I will be removing them to give it a clean/solid look.
There are some great resources available for body work - the site mentioned earlier is one and definitely look at some books on the topic as well. Haynes has a good one available...
cheesehomer
Dec 31, 2015 08:48 AM
Jorlain
Oct 8, 2015 01:57 AM
drumstixer
Sep 29, 2015 03:02 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
