Removing rear bumper, Quick Q's
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
So for the life of me, I can not remove the rear bumper and its plastic screws it has. I tried prying with a screw driver but me being too careful it still are not popping off.
Is there any special tool I can buy to make it easier without having to put alot of force to pop them off?
Re: Removing rear bumper, Quick Q's
Are they the type with the push down center? Or are they regular push darts? I have a small screwdriver I use to pry the center up, then use a pair of needle nose pliars to pull it out. Worse case senario, buy some new ones. They only cost a few dollars at the parts store. Sometimes the top rips. If that happens, push the pin through the outter body and it will pop right out.
Car: 89 FireBird
Transmission: AUTO
There are tools to get them out. You can usually get them at any auto parts stores. I believe they usually refer to them as "interior clip removers" or some sh*t. Its pretty much just a handle with a V notch on the end of them. There are several different styles of them too. I've always had good luck using them.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If they're the push center type, there should be two indentions under the head. I squirt the clip down with WD-40, then insert two flat-bladded screwed into the indentions and pry the center pin out.
JamesC
JamesC
Car: 89 Iroc Convertible
I remove the push in clips with a pair of snips or dykes.I slide them under the head of the clip,squeeze it together and pry up.Just dont squeeze too hard or you will cut the head of the clip off.Works like a charm
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I've used wire snips with success too. I have also used a pair of snap ring pliers with a 90* head that the pins have snapped off of. Those seem to work the best for me as I sometimes have problems with cutting the heads off using the wire snips.
I was about to do that as well but I saw how easy they were and face palmed over my struggling on em before.
well i tried (hense TRIED) to get them off by poping the middle part um then pulling them out, it worked with a couple of them, but most of them broke. so i said $crew it and i cut the rest xP
1992 Trans Am
May 10, 2023 07:19 PM
