firebird fender compatability
Old Jun 30, 2010 | 04:36 PM
401kfirebird's Avatar
Car: 1992 Firebird
Engine: LO3 305
Transmission: 5 speed
Axle/Gears: 3.08 limited slip
ive been searching for this answer on im not really having any luck. i have a 92 firebird with the ground effects. both my right and left fenders need replace. i might be able to save the nose with some body work. my question is this...do i have to get fenders from a 91 or 92 firebird or do fenders from 82-92 work. im having a hell of a time finding fenders that someone doesnt want $300 a piece for. other question is if they arent compatable can i just put an older cars fenders and nose on my car? the fenders and nose are the only thing wrong with this car. its a 5.0 5 speed with 98k miles on it. im the 3rd owner. any help or direction with this problem would be greatly appreciated.
Old Jun 30, 2010 | 04:46 PM
Stephen's Avatar
Car: 87 GTA
Re: firebird fender compatability
82-92 will fit. The only differences that you will encounter, is in the ground fx. Obviously those car tat never had ground fx would need the holes drilled for yours to fit & there was a change in the mounting holes, but that is just a matter of drilling new ones. You do not have to fill the old ones if you don't want to, since they'll be hidden behind the ground fx & nobody will ever know.
Old Jun 30, 2010 | 05:10 PM
Car: 1992 Firebird
Engine: LO3 305
my neighbor told me that the firebird and camaro fenders are the same for these years. is this true or is the old man full of it. hes the kinda guy that is never wrong so i didnt want to argue with him.
Old Jun 30, 2010 | 05:18 PM
Stephen's Avatar
Car: 87 GTA
For the 3rd gens, they are very different. From the center of the wheel opening back, they fit. But the Firebird noses drop a god 3"-4" and are very different. If put on a Camaro nose, you'd hafta swap both & put a complete nose on it as well. A Transmaro. Don't laugh......Its been done!
Old Jun 30, 2010 | 05:25 PM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
There is another difference I found while bolting the front bumper brace of my 89 to my 84. The front lip of the fenders of the 89 is flat, but on the 84 there is an angle under the top hole. The bumper cover brace follows the line of the lip so it's different as well. Hard to explain without a picture, but basically the front lip is slightly different between early models and late models, I guess it changed in 1985).
It's not a big problem, but it will require some hammering to it correctly.
There's an 82 Transmaro around here for sale, it's shocking The wheel arches are different between Firebirds and Camaros, they're more squared on the latter.
Old Jun 30, 2010 | 07:20 PM
Car: 1992 Firebird
Engine: LO3 305
tanks everyone for your input and fast responses. that definately helps me out and expands my fender search. i guess ill keep it to years 85-92. ive had a 92 camaro and now i have a 92 firebird so i kinda wanna keep the firebird front end. although it would be kinda cool to see a transmaro
Old Jun 30, 2010 | 07:37 PM
Stephen's Avatar
Car: 87 GTA
Old Jul 7, 2010 | 12:40 AM
87bluebird's Avatar
Car: 1987 pontiac firebird
Engine: 6.5 turbo diesel
Transmission: t56
Axle/Gears: Ws6 axle
transmaro's sound like a good idea but when you see them they never look rite. besides the wheel wells not matching you also got the ground affects. don't get me wrong i have no problem with putting camaro parts on a firebird or visa versa. but if your gonna do it you should atleast make it look rite.
Old Sep 11, 2010 | 10:23 PM
haroanarchist's Avatar
Car: 87 formula
Engine: LG4
Just to get a little more info
Are ground fx fenders the same as non ground fx fenders?
Just i passed on some that were really straight and if they are i need to go get them asap.
Old Sep 11, 2010 | 10:35 PM
Stephen's Avatar
Car: 87 GTA
The only differences in holes or no holes, to mount the ground fx....And the location of the holes did vary between years of ground fx.
But basically? Yes, all the fenders will interchange.
Old Sep 11, 2010 | 11:06 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Yes, any 85-92 fender will be a direct bolt on. However, the top mounting hole on 82-84 fenders sticks out farther than the later models. Because of that, the front bumper will not fit flush with the top of the fender.
If you have an 82-84 car and 82-92 fender will fit. If you have an 85-92 only an 85-92 fender will be a direct bolt on.
Old Sep 12, 2010 | 12:00 AM
Car: 87 formula
Engine: LG4
Sweet Do you know if the speedo for a 91 6 cyl works for a 87 5.0 The 120 speedo?
Old Sep 12, 2010 | 12:30 AM
Former Sponsor
Car: Too many
The speedo itself will work. However, if you're swapping the entire cluster a couple things will be different. A V6 tach won't read right in a V8 car and V6's have 80psi oil gauges while V8's have 60 psi gauges.
Old Sep 12, 2010 | 12:37 AM
Car: 87 formula
Engine: LG4
The speedo is cable driven?
Old Sep 12, 2010 | 10:21 AM
Former Sponsor
Car: Too many
No, '86 and up speedos are electric.
Old Sep 12, 2010 | 10:56 AM
Car: 87 formula
Engine: LG4
Not to say your wrong
My 87 has a cable connected to the speedo.
The rest of the guages are electric
Old Sep 12, 2010 | 04:39 PM
Former Sponsor
Car: Too many
All '86 and up Firebird speedos are electric so if your cars has a mechanical speedo somebody must have swapped it from an 82-85 car.
Old Sep 15, 2010 | 12:08 PM
Car: 87 formula
Engine: LG4
Ok so if the fenders are diffrent does that mean the bumpers are diffrent.
I found a nice bumper from a 84 will it line up on my 87?
Old Sep 15, 2010 | 12:54 PM
Former Sponsor
Car: Too many
Yes, an '84 front bumper will work. Because of the way the fenders are, you can put an 82-84 front bumper on a later car but can't put an '85-up bumper on an earlier car without modifying the fenders.
Old Jul 1, 2013 | 11:32 PM
eddie jr's Avatar
I know i am digging this thread out of the archives but this is the exact issue i am trying to figure out. My car has had a gap at the top of the fender (between the fender and bumper) for years and i would like to finally fix it. It is an 85 but years ago when i did the bodywork i replaced both front fenders. I am not sure about the one fender but the other came from an 87 or 88, but bother fenders have that piece of metal that sticks out where the top mount hole is.
I am confused though as you are saying the changeover year was 85. That doesn't make sense since the bumper is 85 and the fenders are newer than that.
I was thinking the changeover year may have been 86 and i need a bumper from an 86-90?
Any help would be appreciated.
thanks.
Old Jul 2, 2013 | 07:10 AM
fatalicshock's Avatar
Car: 87 Trans Am
This is my 87 T/A with an 85 IROC front clip wish i knew how to paint or could afford to paint the front clip same color
Attached Thumbnails firebird fender compatability-20130302_110018.jpg   firebird fender compatability-20130302_105945.jpg
PATRIOTIC1911
Northern Great Plains and Rocky Mountain
Oct 7, 2022 10:38 PM
deracer
Apr 11, 2016 12:04 AM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
