reproduction fender? anyone use one?
Car: 1985 Z28
Engine: 305ci 4barrel
Transmission: 5-speed
i need to replace the right front fender on my 85 Z28. i noticed ecklers has them very cheap. has anyone used one of these aftermarket fenders. do they fit well? is there a better source? i assume the GM fenders are no longer available??? any info appreciated....thanks, Rick
Car: 82 camaro berlinetta
Engine: carbed 305
Re: reproduction fender? anyone use one?
ya i just put both on my car and the only discrepency i had with them was the antenna hole was about an inch to far forward causing the power antenna to be miss aligned. otherwise they fit good and look good
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
I used one on my old rs before.I had the same problem with the antenna hole, the only thing I really didn't like about them you could tell they were made with thinner metal they weren't as solid as the stocker's otherwise fit was great. Not sure where mine came from though probably china
http://www.artfiberglass.com/auto/8292firebird.html
I just found this on google
How much is the fender from ecklers
Car: 1992 Formula 350
Engine: 5.7 L98
I tried an aftermarket fender and in my opinion they just don't line up that well. I wound up going to the junkyard and buying two used GM fenders and they fit perfect!
I really want to try and find a good fiberglass set of fenders for my camaro. I know Duraflex has them but I've read that they dont fit well. Any other places?
I want fiberglass so I don't have to worry about rust and the little weight that it takes off could help too.
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
Try finding used body parts in your area. I been picking up lots of parts for my car from ads on craigslist. Repro parts may not always fit 100%. Used parts are still cheap for our cars. Also stock fenders are pretty light.
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
88camaro, as long as they're coated well, they won't rust.
Car: 1989 Firebird
Engine: 350 TBI
Transmission: 700R4 (Sadly)
Axle/Gears: ?.??
I think its best to find the fender in a junkyard or off another car cause it lines up better and cheaper too.
Car: 1989 Firebird
Engine: 350 TBI
Axle/Gears: ?.??
I used to live in Northern IL and all cars have rust unless they are new. When I drove my Camaro in the winter I found if you wash your car more often it helps, but in IL they use salt on the roads and it just destroyed cars.
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
the aftermarket fender that I had was 3/16 shorter from back to front than OEM and it didn't line up right. I couldn't give it away so I scrapped it with my old differential for $10. Have some patience and look for used fenders on craigslist or a junkyard....I've picked up both sides for $40
morrow
Jan 13, 2024 12:29 PM
