Weatherstripping
Weatherstripping
Hey Guys I have a 1989 trans am and it is leaking in the back seat and I can't
Tell where it is leaking from I'm thinking it's the hatchback weather-strip I highly dobht that it's the t tops but I would like to know if you guys now any good weather-stripping for the hatchback and the window weather strip for the bottom of the windows thanks
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Weatherstripping
welcome to TGO! we offer both factory GM seals and aftermarket Metro replacement seals for the 3rd gens if you're looking to get something new for the bird.
Trans Am weatherstripping
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
Hey man, that is actually a VERY common leak in our cars and unfortunately it IS coming from the t-tops. The water sneaks in by the center of the t-bar and travels to the back of the center of the roof rails. The water actually comes out through the little holes by the screws for the t-bar. This is due to a flaw in the adhesive pattern used by GM. There are a few ways of combating this. One is to fully replace the weatherstripping and use a modified method of applying the adhesive(that's what I did), the other is to fill the gaps in the front and rear of the t-bar with silicone or weatherstrip adhesive. That really is the only shortcut that I am aware of. Obviously reinstalling the weatherstripping is the best method, but that is not always possible due to time or money constraints. Do a search of the forum on this topic, I know there is actually a wealth of information about this here. I recall a few threads where pictures were included to help identify the exact place to put the silicone if that is the way you choose to remedy the situation. Good luck and let me know about that headliner retainer.
Car: 1990 Firebird Formula
Engine: 305 V8
I have the same problem. I just thought it was from the the top of the rear hatch. My weatherstrip is 20 years old and needs to be replace soon anyways. Does anyone sell the metal trim piece that goes around the rear hatch?
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
No one that I know of or have been able to find. Good luck searching. I'm having problems with my T Tops leaking as well, trying to find out why!! WHY!!!! hehe About the only downer about my car really.
DAN -
I JUST PUT NEW WEATHERSTRIPPING ON MY CAMARO HATCHBACK AND IT STILL LEAKS FROM THE RAIN. SHOULD I USE CAULKING OR SEALANT ON BOTH SIDES OF THE NEW WEATHERSTRIPPING? WHAT DO YOU THINK?
THANK YOU,
MARK
THANK YOU,
MARK
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Edit Oops just read where you said it was leaking in the seats. Yep t-top leak. Lots of sealer. Good luck
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I just installed a complete weather stripping kit I bought from 1A,Doors,Hatch,T Top,etc.
and my main leak I found was under the glass hold down,the piece of metal that's in the middle were you put the glass in,well their are couple of seal stripes under that and they need to be replaced,be careful there's a couple of hidden screws under the rubber.
It's been 2 wks.without a leak so far.and it rained pretty good the night I installed them.
Car: 1987 Trans Am
Engine: LQ9/L92
sorry for the late arrival (took a couple days to visit the family), but both manta and white gold touched on what i would have recommended. Water has a way of being sneaky in how it gets into our cars - trim pieces have a way of hiding things. On the t-tops, it is super important to get all the old sealant up and check for rust. The roofs have a ton of cracks and crevices that water sits in and eats away over time. I fear what I'm gonna find on my own when i go to tackle the seals on it next year....
