Hey Guys Quick Question!
Old Dec 19, 2010 | 11:44 AM
BrandonSB's Avatar
Car: 1987 Z28 Camaro
Engine: 30Slow
i have my camaro outside this winter cause i dont have acess to a garage.. unfortunatly . what would be the best way to winterize it (body, UNDERbody from rust) any input is appreciated thanks!
Old Dec 20, 2010 | 02:42 PM
BrandonSB's Avatar
Engine: 30Slow
Re: Hey Guys Quick Question!
bump, noone?
Old Dec 20, 2010 | 03:32 PM
aqualordx93's Avatar
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
not sure, drive it as little as possible so no salt. and get a good car cover. thats what i got right now
Old Dec 20, 2010 | 03:44 PM
BrandonSB's Avatar
Engine: 30Slow
thanks! yeah thats what i was thinking, im more worried about the underbody not too sure if itll rust to hell just sitting there, wonder if theres some wax u could throw on it or something.
Old Dec 20, 2010 | 05:13 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
I have been told that there is nothing to worry about if you just have it sitting there. Also if you have driven it once on the salty streets you should power wash the underside to get all the salt off to prevent rusting. That's what I did and I threw on this tarp ($10) along with 50 ft of rope ($1) to hold it down. With mine I zigzagged it under the car back and forth and looped the rope through all the grommets and around the back and tied it down. Since I ran out of rope I tied some fishing stringers together around the front end to keep it from inflating and ripping. Mine already survived through a whole day of 50+ mph winds reaching about 70 mph at times.
Old Dec 20, 2010 | 05:37 PM
BrandonSB's Avatar
Engine: 30Slow
thanks! all i was worried about, and i will pick up a car cover, i have tarps but i heard the moisture can rust the body?
Old Dec 20, 2010 | 05:42 PM
It can if moisture is on the car when you put the tarp on but I have not heard of it happening when the car is dry and roped down good.
Old Dec 20, 2010 | 05:54 PM
BrandonSB's Avatar
Engine: 30Slow
thanks alot for your input 1987!
Old Dec 21, 2010 | 02:40 PM
RagRoc's Avatar
Car: 88 IROC Convertible
Transmission: M5
Axle/Gears: 9-bolt 3.45
Make sure the tarp doesn't contact the ground around the car. Air must be allowed to circulate under the car to prevent mositure from forming. Also do not allow the snow to drift around the sides and enclose the bottom of the car either.
Old Dec 21, 2010 | 03:02 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
My biggest fear with car covers, of any kind, is if you get any dirt under them, then you have a sandpaper cover. Just the texture of the cover can be abrasive. Remember the old LeBra's? They protected the paint from rock chips but wore the paint off. Maybe if you took it off when you could and wash or make sure everything is clean? JMO Good luck
MustangBeater20
Oct 29, 2022 09:20 PM
Jorlain
Aug 24, 2022 05:11 PM
Infested
May 22, 2018 11:56 PM
Zachattack0925
Aug 12, 2015 09:52 PM
squiggy2
Aug 9, 2015 09:30 PM
