Spoiler fasteners
Old Jan 17, 2011 | 02:45 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Spoiler fasteners
Does anybody have any pics on what the spoiler clips look like.Their the
whitish looking clips that fasten down the 86 TA black rubber spoiler to the hatch.Really having trouble trying to find these.I really appreciate your help.
Old Jan 20, 2011 | 02:32 AM
firerider76's Avatar
Car: 1986 Trans Am
Re: Spoiler fasteners
The part number is 20556524. It is discontinued IIRC.
But i ran the locator and there are some at a dealership in PA. They cost 4.83 each.
Their number is 1-888-870-0280. Best I can do for you.
This is the plastic clip.
Metal clips for the spoiler and frameName:  DSC04048.jpg
Hope this helps.
Old Jan 20, 2011 | 11:00 AM
mantaguy's Avatar
Engine: 5.0 EFI
Thanks firerider,I was afraid I was going to order the wrong part no.and those clips are what I need.Went to a GM dealer and they weren't sure if that was what I needed.Didn't want to order because their is no returns.
Thanks a lot,now I'll order them.
Old Jan 20, 2011 | 08:40 PM
Car: 1986 Trans Am
No problem, glad I could help.
Old May 16, 2012 | 04:55 PM
WestTA310's Avatar
Car: 1986 Firebird Trans Am
Engine: 305 TPI V8
Metal clips for the spoiler and frame.
Hope this helps.
Do You Know Of Any Dealer Or Store That Migh Sell These In The Los Angeles Area?
Old May 16, 2012 | 05:06 PM
mantaguy's Avatar
Engine: 5.0 EFI
You have to go to a GM Dealer and they will give you a list on who has them in stock.Good luck finding them,they are very hard to find.When you get the list you will see that the dealers listed only from 1 to 3 in stock,your going to have to call most of them to accumulate the six you need.I did it a year ago and luckily I got them.
Old May 16, 2012 | 06:24 PM
mantaguy's Avatar
Engine: 5.0 EFI
Just what is it that you need,I'll be putting a new spoiler on in the next week,it was delivered today from Hawks,so I'll have the clips and the metal clips for the spoiler
Let me know.
Old May 16, 2012 | 07:50 PM
WestTA310's Avatar
Engine: 305 TPI V8
I Needed The Metal Clips And The Two Bolts Were The Screws Enter They Were Rusted And The Screws Broke Inside The Bolts So I Need The Whole Spoiler Mounting Kit...I'm Restoring And Painting My OEM Spoiler
Old May 16, 2012 | 08:01 PM
mantaguy's Avatar
Engine: 5.0 EFI
How are you going to get the broken studs out?
Old May 16, 2012 | 08:17 PM
WestTA310's Avatar
Engine: 305 TPI V8
The Studs And The Bolts Are Rusted Together So They Might Break If I Force Them Out...I'll Try To Clean Them And Use Oil...Or Does Anyone Sell These?
Old May 16, 2012 | 08:28 PM
mantaguy's Avatar
Engine: 5.0 EFI
I had that problem with this spoiler,I drilled out the piece of metal and I used a nut,I glued it in with weatherstripping adhesive and let it sit for a couple days and it worked out OK.
Old May 16, 2012 | 08:59 PM
WestTA310's Avatar
Engine: 305 TPI V8
I'll Try That Good Idea But What About The Clips?...Check Out The Pics I Posted Of The Spoiler On My Album
Old May 16, 2012 | 09:12 PM
mantaguy's Avatar
Engine: 5.0 EFI
The clips pull out, you can replace them if you find them.
Old May 16, 2012 | 09:49 PM
WestTA310's Avatar
Engine: 305 TPI V8
Where Can I Find Them?Or Can I Do Something Else Like What You Did With The Glue And Nut...I Posted A Picture On My Album Of The Actual Car So That You Can See What Got Left On The Hatch Are Those Good Or Do I Replace Them Too?
Old May 16, 2012 | 09:57 PM
mantaguy's Avatar
Engine: 5.0 EFI
You keep the ones on the hatch,don't remove them,you could damage the rear window.
Go to the "Spoiler Sale" thread,last page,82taRecaro posted a site you can get an idea from,it's something I did before I found clips.
Old May 19, 2012 | 06:44 AM
stahrman0612's Avatar
Car: 1986 Trans-Am
Engine: 305 4 bbl
Transmission: 700R4 auto
Axle/Gears: posi
How are you restoring and painting the black rubber OEM spoiler??? Thought there was nothing you can do with it??
Old Aug 26, 2012 | 06:16 PM
rich24's Avatar
do you put the clip in the spoiler or the window frame and at what direction do they face any pics would be great
Old Aug 26, 2012 | 06:36 PM
Speed Racer X's Avatar
Car: '09 Pontiac G8 GT - 12.76@109
Engine: 436HP 6.0L
Transmission: 6L80E
Axle/Gears: 2.92
From the service manual.... disregard first picture of pedestal tail.
I followed this procedure about 3 weeks ago when I put my OE rubber one back on and it worked fine.
Get a helper or two.
Old Aug 26, 2012 | 07:10 PM
mantaguy's Avatar
Engine: 5.0 EFI
These directions are for the 85-86 TAs
Old Aug 26, 2012 | 07:20 PM
mantaguy's Avatar
Engine: 5.0 EFI
If you need clips I have six new ones.
Old Aug 28, 2012 | 04:27 PM
rich24's Avatar
thanks for the information. the problem im having is i cant push the spoiler rearward to line up the bolt holes. i think the clips are catching on the window channel. is that little piece coming off the clip suppose to catch the window channel or be in it.
thanks rich24
Old Aug 28, 2012 | 06:54 PM
mantaguy's Avatar
Engine: 5.0 EFI
The bottom of the clip is grooved so it would slid forward to lock it in the molding.That little piece is supposed to be kinda like a guide it holds the clip in place at the end of the molding.Set them up just like in the figure 62 that speedracer has.
Old Mar 30, 2014 | 01:31 PM
nyypride1987gta's Avatar
Car: 1987 firebird gta
Transmission: auto
Axle/Gears: not sure
i need help looking for 6 fastners . for rap around spoiler . i have all the metal clips that go on trim . thanks nyypridegta87
Old Mar 30, 2014 | 01:44 PM
mantaguy's Avatar
Engine: 5.0 EFI
You'll have to go to your local GM Dealer and ask them to look up P/N 20556524 (that's the clips)and ask if he,she,would take the time and look up what dealer has any in stock,then your going to have to buy them from multiple dealers as that's what I had to do to get 6.These things are the hardest things to find,but their out there.I sold mine awhile ago.
These look just like them
http://www.clipsandfasteners.com/GM_...p_p/a19390.htm
Old Mar 30, 2014 | 01:52 PM
Transmission: auto
Went there , only two dealer were showing them . Called , they didn't have them . Discontinued . Thanks 4 the reply.
Old Mar 30, 2014 | 01:55 PM
mantaguy's Avatar
Engine: 5.0 EFI
For the few bucks that these cost http://www.clipsandfasteners.com/GM_...p_p/a19390.htm
I would give it a shot.
Old Mar 30, 2014 | 02:16 PM
Transmission: auto
Cool , I'll look into them . Thanks
Old Mar 30, 2014 | 02:33 PM
Engine: 436HP 6.0L
Transmission: 6L80E
Axle/Gears: 2.92
I bought mine from P.D.Q. Supply in NY aka autobodysupplies dot com
PN 89-6590 from Car-Pak which replaces 20556524. Look for clips & fasteners/domestic vehicle clips/click on car-pak catalog at the top/click on moulding clips/find part at the top left of page 170.
Whole box was cheap.
Good luck.
Old Mar 30, 2014 | 02:34 PM
Transmission: auto
We found a short screw that has a head that slides right in. It fits nice and thigh .
Old Mar 30, 2014 | 02:40 PM
mantaguy's Avatar
Engine: 5.0 EFI
That's what I did before I bought the clips, and it does work!!
sp8ty
South East Region
Sep 24, 2018 03:55 PM
Bohemian
Aug 15, 2017 05:11 PM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
F-body-fan
Nov 4, 2015 06:13 AM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
