Will these work?
Old Jan 26, 2011 | 08:52 AM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
Will these work?
replacing the wheel wells in my 87 camaro will these tubs work?
http://www.jegs.com/i/Jegster/550/40525/10002/-1
Old Jan 26, 2011 | 09:29 AM
Steel Armadillo's Avatar
Car: '85 Sport Coupe/Z28
Engine: N/A 350
Transmission: TH350
Axle/Gears: Factory 10-bolt w/3.08
Re: Will these work?
Depends, how good are you at fab work? If you are determined and are good at fabbing, then yes, they will. Or were you asking about the size?
Old Jan 26, 2011 | 11:17 AM
yeah size wise i am ordering them someone else is installing either a friend of a friend and if he doesnt turn up in time then the body shop when the car goes out for paint
Old Jan 26, 2011 | 06:06 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
those tubs are not structural, so no, unless you are planning a cage and other chassis work, they wonr do it for you.
which wheel well are you working on, rear for front?
Old Jan 26, 2011 | 06:33 PM
rear drivers side
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
