92 fron lower lip help
Old Apr 8, 2011 | 01:42 PM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
ok i have a 92 camaro rs v6 soon v8 any way i whent and got a 92 front lip from a rs 305 car it had this big like sheld hooked in to the varey front part of it is that to suppert it from dropping ? my car dose not have it and the clips in the one i got off to day snaped away from the lipe is there a way to suppert it if it is need then that odd looking thing thanks for any input and sorry for any bad spelling im not the worlds bast
Old Apr 8, 2011 | 02:32 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 92 fron lower lip help
I think you are referring to the black piece between the radiator air dam and the very front lip - it's basically like a cover of sorts, I don't think it has an real function (other than scraping the driveway ) Mine is kinda bulbeous (for lack of a better term) and bows downwards kinda - thus it always scrapes the driveway - I always worry it's the chin spoiler scraping on my car, but it's that plastic piece.
Old Apr 8, 2011 | 02:39 PM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
camaronewbie your talking about the air-dam? it helps with cooling. you will notice a fair bit of difference in temp if you didn't have it.
Old Apr 8, 2011 | 03:21 PM
Car: 1992 RS
Engine: Carbed 350
No - not the air dam. There is a plastic covering under the front of the car, between front lip and the air dam - that's what I'm referring to - and I thought the OP was referring to.
I know the air dam itself is critical and quite neccessary!
Old Apr 8, 2011 | 07:20 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
that is the part im talking about is it need to make the ip look right and not droop
Old Apr 8, 2011 | 08:05 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
The air dam does not support body work. It directs air up to the radiator.
Can you post a pic of what // where it broke?
If just the plastic mounting clip(s) that holt the lip up broke, check a local u-pull-it type place, or take a good 1 to your local auto parts store & see if they have them.
Old Apr 8, 2011 | 08:17 PM
Car: 1992 RS
Engine: Carbed 350
I don't think that plastic piece affects the "shape" of the front chin spoiler, at least not much if it does. I'd say, install your chin spoiler, then hunt down another 3rd gen, park side by side, and look under to see if theirs looks much different than yours. Also, take a highway run - have someone else drive your car, while you drive another car, and see if the presssure of highway speeds affects the shape while accellerating.
If it appears to be a concern for you, you can always, if nothing else, go to a arts/crafts store, and buy a plastic portfolio that would be large enough to cut your own piece out of, might cost you $15, and make your own piece.
Old Apr 8, 2011 | 08:53 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
the part your talking about will have an effect . not on cooling but appearence . over a period of time the front GFX will start to droop . the duct panel (for lack of a better word) does support the front GFX . you may be able fashion a couple of fore & aft supports to keep it in line . i have seen some made from PVC pipe . i said i have seen it done , i have not done it . if you can find another , even with the holes torn out . it can be used with new nuts & bolts with large washers . this i have done with good results . whatever you do , good luck .
Old Apr 8, 2011 | 10:03 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
ok so i need to go back and get the odd looking thing thanks for all the help guys
Old Apr 8, 2011 | 11:25 PM
Car: '87 Camaro
So is OP talking about the arc shaped scoop?
Old Apr 8, 2011 | 11:52 PM
puma1552's Avatar
Geez, is it so hard to hit spell check, or better yet, pay attention to basic spelling and grammar rules in school?
You certainly aren't the world's bast, that's why we have spell check. Learn to use it, tired of reading incoherent posts on this site.
Old Apr 9, 2011 | 10:42 AM
Car: 92 camaro rs
Engine: 3.4v6 sc
puma1552 go (geez) ur self if u dont like it than dont post you had nothing good to say so don't say it at all it's ppl like u that give forms a bad name from flaming ppl over some thing stuped cuse u have a lack of self asteam .
Old Apr 9, 2011 | 11:18 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Originally Posted by puma1552
world's bast
Old Apr 9, 2011 | 01:01 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
puma1552 i think it's you that needs to use that spellcheck cuse bradley23150
just schooled u
Old Apr 9, 2011 | 01:40 PM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
I think I have to agree with puma.
I´m not a native english speaker and trying to make sense of posts like the first can be quite a daunting task.
The problem there is that it´s missing some of these: ..........
Some of these ????
And maybe some basic grammar. Where do sentences stop, where do new ones start. Capitals are not only big cities, they also are a great help in helping others understand what you´re trying to communicate.
As to the question at hand, the part is called "front fascia reinforcement" which exactly describes what it does.
The material used to manufacture the front fascia or nosecone is somewhat old fashioned, which is no surprise given that these cars are over 20 years old by now. The nosecone is flexible up to a certain degree, and to prevent it from deforming too much under highway speeds the nosecone received a reinforcement panel. Some modern plastics would be able to support this shape as well as be flexible up to this degree. Back in the 80´s the inability of the plastic used to support it´s own shape was solved by adding a backing plate that supports the shape.
(Question. Do the early 3rd gen Camaros have this reinforcement panel as well? I do not see it in any of the repair manuals. Only for later third gen camaros)
A fiberglass nosecone would not require the reinforcement, but would also not be able to withstand impacts of any kind without being damaged.
Replacing the plastic part by for instance a small brace made of small metal rods in a V shape woud work, but also form a serious hazard in case of an accident (especially when pedestrians are involved). If yours is broken, best find a replacement
gta892000
Aug 11, 2019 11:16 AM
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
jbates346
Oct 21, 2015 01:50 PM
jaysfs
Sep 18, 2015 11:59 AM
Stryker412
Sep 7, 2015 09:11 AM
