i got a leak, dont think its the t tops
Old Jun 14, 2011 | 05:18 AM
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
i have a leak that dips or spills out of the hole in the t top bar right behind were the t tops end. is it possible that the seals for the hatch are bad or is it still the t tops? ill try to put a pic up later on in the day.
Old Jun 14, 2011 | 11:17 AM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
Re: i got a leak, dont think its the t tops
here a picture i circled were its leaking from.
any ideas?
Old Jun 14, 2011 | 11:44 AM
Carpaholic's Avatar
Car: 88' Iroc
Engine: 5.7 liter
Axle/Gears: 2.77 posi
I think I can explain where your leak is coming from.
You can see the gasket material that's torn up and a bunch of rusty/glue like residue in the picture with the T-Bar removed. Under this material you will see a few pieces of sheet metal that overlap. This is on both the front and rear areas as marked. More than likely that is where your water is coming in from.
If you were to take some water and pour some on this overlapping sheet metal, the water should run out of the hole you marked in your picture. It may also run out to the sail panels too. Mine did.
Use a wire wheel and clean that area off really good. Then, get some silicon and seal up those seams. I went a bit overboard with mine but its sealed. Finally, re-attach the weatherstripping with that 3M Weatherstripping Adhesive or whatever else is comparable.
Old Jun 28, 2011 | 10:28 AM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
i pulled the t bar off yesterday cleaned it painted it and resealed it to the car.also resealed the weather stripping. time to see if it leaks or not now.
Old Jun 28, 2011 | 11:43 AM
Carpaholic's Avatar
Car: 88' Iroc
Engine: 5.7 liter
As long as you got that overlapping sheet metal sealed up you should be ok. Also, leave your headliner out for a week or two and see if anything leaks.
Old Jun 29, 2011 | 04:43 AM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
what headliner.
Old Jun 29, 2011 | 07:59 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Originally Posted by 7thdarkangel
what headliner.
LOL!
Old Jul 4, 2011 | 02:49 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
haha good one =) let us know how the results turn out. in the words of early cuyler of the squidbillies: "see if that sumbitch will leak now!"
xxx3man`
Sep 23, 2015 10:37 PM
mike_c
Aug 27, 2015 04:32 PM
TheExaminer
Aug 26, 2015 04:59 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
wayshegoes
Aug 17, 2015 12:00 PM
