HELP!!!!! upper hinge pin replacement gone wrong!!
Old Jun 14, 2011 | 09:20 PM
Melissa666(6)'s Avatar
Car: 1985 z28
Engine: 350 4 bolt
Transmission: 350 turbo
Axle/Gears: 308
hey guys, i could really use a hand with my problem. ok, so my passenger side door started dropping when i open it, so my dad decided to replace the hinge pins, nbd right? WRONG! its the upper thats gone. we took the door completely off after buying an upper hinge pin from napa, and after the old pins were removed, discovered not only is the pin i bought NOT an upper, its not even long enough to get through the hinge. no one seems to carry the 2 piece pin kit, my car is doorless, my door is pinless, and its the only car i have on the road right now and i have to be somehere tomorrow evening. im biking to the dealership tomorrow, will they be able to get the pins and bushings for me?
Old Jun 15, 2011 | 05:06 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Re: HELP!!!!! upper hinge pin replacement gone wrong!!
Google - Top Down Solutions. They sell the upper hinge pin kits to repair 3rd gen doors. Be prepared they are not cheap, but then again thats the story for most parts for our cars...
Old Jun 15, 2011 | 09:51 AM
Car: 1985 z28
Engine: 350 4 bolt
Axle/Gears: 308
Yeah i know they do, but express shipping wont get it here tomorrow at the latest. i have to attend a wedding friday morning, i need the parts NOW!
Old Jun 15, 2011 | 10:07 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
It's a pain but you could put the old one back for now. Unless you destroyed it taking it out. Sometimes you just can't make it happen.
Old Jun 15, 2011 | 12:11 PM
Car: 1985 z28
Engine: 350 4 bolt
Axle/Gears: 308
the old ones are absolute garbage. theres no way they can go back in, theres no way i can get the parts online as the postal service here is on strike. after i cool off from biking all over town (im from out of town), im gonna go weld the door back on and go dukes of hazzard style until the winter then figure out what to do.
Old Jun 16, 2011 | 10:19 AM
Car: 1985 z28
Engine: 350 4 bolt
Axle/Gears: 308
ok so my dad figured out something to do to get the door back on the car and semi-functional for now and i ordered the kit from top-down solutions. ups says it will be here june 23. $118 from california to ontario canada isnt too bad. looks like ill be taking my door off AGAIN in a couple weeks :|
Old Jun 27, 2011 | 01:24 PM
Car: 1985 z28
Engine: 350 4 bolt
Axle/Gears: 308
has anyone in canada ever ordered the parts from tds? mine arrived on thursday, and i payed my $22 shipping and the $96 for the pins. now ive recieved an email from Lon Salgren wanting another $42 for export fees etc. i've ordered from the US before and never had this before.
Old Jun 27, 2011 | 01:34 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Whoever delivered the parts to you (UPS?) must have dropped it off, and not charged you for the duties. Lon should have written on the form that the receiver is billed the export duty, instead of the sender. Now he's stuck with the bill. That's a UPS or Lon screwup, but ultimately your bill. Whatever you do, don't screw Lon out of the $44. That's exactly the reason why so few companies even want to deal with us shifty Canucks $22 for shipping only sounds right, $44 is right for duty. Small value parts we get raped on, especially when using UPS/DHL/FEDEX. They have a $15 minimum fee, then the actual tax, then the xyz fee, and the doohickey fee, etc etc. It's criminal what they charge, but the alternative is to use the postal service (and you know how that is now...), but normally that just adds a *bit* more time to the delivery, but lessens the fee considerably.
Or you just get it shipped to a delivery service south of the border, and drive over and pick it up... Depending on how close you are to the border.
PS - Did your dad just bolt the door on for now? ie, bolts instead of pins?
Old Jun 27, 2011 | 01:57 PM
Car: 1985 z28
Engine: 350 4 bolt
Axle/Gears: 308
i allowed the charges, i just wont eat for the week i guess.
he had some bearing like bushing things hanging around in the shop that he put in and drilled them out and put a put and bolt and nut through it. thank god for a garage full of crap. instead of the door falling when i open it now, it lifts up lol. the striker pulls it down even after its been adjusted
Old Jul 2, 2011 | 08:55 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Smart Dad..........
Old Jul 2, 2011 | 11:30 PM
Car: 1985 z28
Engine: 350 4 bolt
Axle/Gears: 308
Originally Posted by Gallileo60
Smart Dad..........
hes a millwright. he can do anything. the passenger door pins he put in seem to be working fine, and the drivers door has just started to drop when its opened, so maybe the $160 i spent on door pins will go to that door instead
Old Aug 22, 2011 | 07:30 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
i had a guy tell me that he changed upper and lower pins/bushings with the doors closed and he did it through the inner fender (removed inner fenders) without removing the doors,,is this method possible?
Old Aug 22, 2011 | 09:51 PM
rfox's Avatar
I like the idea and would also like to know. Would it make it easier? I did one with the door open on the car and that is a royal PITA I need to do both doors and am not looking forward to it
Old Aug 22, 2011 | 11:01 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
while you guys are at it take a look at the seam sealer around the hinges where they are welded on the door......pry it off and see if you notice any rust.......I just did mine and found some around one of the lower hinges.
Old Aug 23, 2011 | 07:32 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Sounds like you have some nice mods on your suspension...
Old Aug 23, 2011 | 09:00 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
yeah thanks...maybe someday I'll be able to drive it and see how it handles....lol
Old Sep 4, 2011 | 09:31 PM
mooch1's Avatar
Transmission: T5 WC
anyone?
Old Sep 5, 2011 | 03:44 PM
chevman24's Avatar
Car: 88 and 02 Camaro's
Engine: L96 (LS) and LS-1
Transmission: auto, 6 speed
Axle/Gears: 3.42 gears for both
Hawks third gen has similar replacment pins. I just got a set of these that appears stronger than the ones at TDS, and Hawks.
http://cgi.ebay.com/ebaymotors/_W0QQ...KQ3aMEWAXQ3aIT
I looked at the sellers history and it seems he's sold quite a few of these. 40 bucks is cheap. Well considering it looks like 10 bucks in parts, the person is making a ton on these. Apparently the people that bought them are happy with the results.
Old May 31, 2014 | 05:25 PM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
http://www.ebay.com/itm/370740540204...84.m1497.l2649
those fit well for me
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
evilstuie
Jan 9, 2020 08:29 PM
86IROC112
Apr 9, 2016 10:20 PM
Leggman1
Aug 6, 2015 04:15 AM
