headlight motor issues
Old Jul 16, 2011 | 12:48 PM
mrconor44's Avatar
one of my headlight motors continues to run for about 10 seconds after its already flipped up/ down , is there a way to adjust these or am i going to need to replace the unit?
Old Jul 16, 2011 | 02:28 PM
Flightoficarus's Avatar
Re: headlight motor issues
So the motor itself continues to spin after the light is flipped up/down? Haven't heard of that one happening, but it sounds like it might be an issue either with the motor itself, or some kind of electrical one possibly. Does it try to force the light further up or further down as it's still spinning?
Old Jul 16, 2011 | 10:13 PM
bearterror23's Avatar
Car: 1989 base firebird
Engine: 305 tbi
Transmission: t-5
Axle/Gears: no idea
sounds exactly like what mine did, but after a few months it got worse (wouldn't come up right away) and eventually quit working.
i bought a rebuild kit from tds and now they work great and shut off when they are suppose to.
It's pretty easy to do. took me maybe 3 hours. i could prolly done it quicker but i took my time to make sure i did it right.
here's the link for 87-92 birds
http://www.top-downsolutions.com/del...pair-p-87.html
or 82-86 birds
http://www.top-downsolutions.com/hea...ero-p-118.html
Old Jul 16, 2011 | 11:05 PM
defaced's Avatar
Car: 1987 Firebird Formula
Engine: 355
Axle/Gears: Posi, 3.23
or 82-86 birds
Just take the motors off and take them apart. Take the motor housing to Lowe's and look for some nylon spacers and match them up to old ones as close as you can. That is, if one of the old ones is still in tact. When I rebuilt mine, the spacers were a little big so I ground them down a little bit with a bench grinder until they fit. Each motor only takes 3 bushings. The old ones are basically nylon bushings, but spacers will work just as well.
I did this with both of my motors and spent maybe $3 on the spacers. Had about an hour in taking them out, rebuilding them, and reinstalling them. They work like new now.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Aug 17, 2015 02:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
stalkier
Aug 13, 2015 12:59 PM
