Body Filler Heat Resistance
Old 07-18-2011, 10:52 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Since my engine died in my Camaro and I don't have the $$ right now to rebuild it, I have decided to take it off the road for a few years and go back and finish off the engine bay like I wanted to the first time I had the engine out while I'm saving the money for my engine build and T56 swap. I want to smooth everything out and weld all the seams up along with some other work.
I know its been done a lot on here by other members and I'm wondering if some of you who have done this have had any problems with the body filler cracking or coming loose due to the heat and temperature fluctuations in the engine bay. Also, what filler did you use?
The car will be my summer daily driver again when it's done and I want to make sure whatever I use will hold up.
Old 07-19-2011, 02:53 PM
JohnStamos's Avatar
Re: Body Filler Heat Resistance
considering heat is a method to remove body filler for some hacks of the body work world.. It is not meant to take such high temperatures. Some may disagree, but look up methods to remove body filler.. you will find "torching it off"
http://www.spraypaintcar.com/bondo-b...er-basics.html
Old 07-19-2011, 06:06 PM
Dusk2600's Avatar
Car: 85 z28,01 sonoma,05 envoy
Engine: 305 tpi
Transmission: 700 r4
Axle/Gears: stock
sorry to hear your motor died, but i did laugh at your engine explaination
Engine: Knockin' like it's at heaven's door
Reminds me of that steven king movie christine where the car plays "keep on knockin but ya can't come in!"
Old 07-19-2011, 07:02 PM
Nikole's Avatar
Car: 1992 RS
You can buy a high temp catalyst to mix into the filler. Just research it before you plan on starting your project and buy the one that best suits your needs and budget.
Old 07-19-2011, 10:45 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Thanks. I wasn't laughing at the time, but I've come to accept it. I haven't touched the car since I pulled it into the garage though, its still too frustrating to think about it.
Old 07-19-2011, 10:46 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
I've never heard of any high-temp catalyst, I'll have to look into that.
Old 07-19-2011, 10:47 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Can't say I've ever heard of that either. I would imagine that would REALLY stink.
Old 07-19-2011, 11:01 PM
Nikole's Avatar
Car: 1992 RS
I know that Evercoat carries a high temp catalyst.
Hotrodboba400
12-10-2019 07:07 PM
my86bird
10-23-2015 12:20 PM
Stryker412
09-07-2015 09:11 AM
TBRays98
09-06-2015 05:05 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Body Filler Heat Resistance
