RS rear spoiler to high rise, quick questions
Old Oct 25, 2011 | 09:34 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Wanting to go from my RS spolier to the high rise. Can i modify the rear deck lid, or do i need the factory high rise deck lid? Reason being, there are several holes in my deck lid from the RS spoiler that i dont think the high rise will cover. Also how big of a pain is it to change out deck lids if i have to go that oute?
Old Oct 25, 2011 | 10:33 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: RS rear spoiler to high rise, quick questions
There will also be holes in the rear quarters - they will all need to be filled.
Old Oct 26, 2011 | 04:42 AM
waterboy87's Avatar
There are five holes in the decklid you will have to weld shut. None of them get re-used with the high-rise/Z28 spoiler. I just did this about a month ago.
Old Oct 26, 2011 | 12:46 PM
TranzMutation's Avatar
Car: 1989 Camaro RS
Heck now im curious waterboy how bad was it to do? i've been looking for just the decklid with spoiler already on it, i've heard a lot of ppl have problems lining the wing up
Old Oct 26, 2011 | 03:03 PM
Coolwheels84's Avatar
Car: 84 SC Camaro (92 Tribute)
Engine: V6
Transmission: M5
I just put a '91/2 wing on my '84. I used my stock decklid and redrilled the holes for the new spoiler. Everything lined up fine. I have a friend that is a welder. He is going to close up my old spoiler holes for me. I'm also changing the gfx to the '91/2 style to match.
Old Nov 3, 2011 | 03:14 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
I just completed this, well, had some help with the welding, but its not too bad. Those holes are too big to be filled and needed to be welded, grinded and filled.
The wing lines up good, just need to drill the 6 new holes for the bolts to fit through. I started with small drill bits then worked up to larger bits until it fit and lined up right.
Old Nov 3, 2011 | 11:16 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
anyone have pics of this? did you use an OEM wing or aftermarket wing?
Old Nov 4, 2011 | 01:00 AM
porkenstein's Avatar
Car: 91 RS Convertible
Engine: LSA
Transmission: 6060
Axle/Gears: 373
You didn't ask for my opinion but I think the stock rs spoiler is so much better looking. The high one to me has always looked like an add on with the regular looks like it's just meant to be on the car. Just my two cents worth.
LilHot
South Central
Apr 13, 2026 11:46 PM
colton_carlson
Mar 8, 2019 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
