ttops
Old Jan 1, 2012 | 09:39 PM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
ttops
ok i was gaven a free set of glass ttops but the seals were way to sort were that meet the sides and the front were the lach go throw seemed way lose unlike my plastic ones can any one help me? not to sure on thes cam off a 92 firebird and lol the floor was rusted out on the drivers side i dont want that to happen to me mt tops dont leak.
Old Jan 2, 2012 | 09:03 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: ttops
Very difficult to read this post!! Are you familiar with punctuation? It helps break out the sentences into segments which leads to improved readability. You also might want to use the spell check feature.
As for the TTops, can't help out without knowing which ones you have. There are C&C aftermarket plastic tops and there are factory plastic (acrylic) tops. The glass tops are a direct swap with the factory acrylic tops.
Old Jan 2, 2012 | 09:08 AM
carlos64030's Avatar
Car: 1991 Trans Am GTA
Re: ttops
Wow...
Old Jan 12, 2012 | 08:38 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: ttops
will glass ttops from an 82 berlinetta fit on a 92 firebird?
Old Jan 13, 2012 | 11:28 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: ttops
if theyre both the same type, ie c&c tops, or factory tops. c&c tops interchange with c&c tops, factory interchanges with factory. they dont interchange between the 2.
Old Jan 13, 2012 | 01:58 PM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
Re: ttops
There are two (that I know of) types of latches on the factory T-Tops (one hook style and one "pin" style). The 82 ones are likely hook and the 92 pin (I think somewhere in the middle they changed). So they will fit the opening but will not latch down.
To get them to work you will have to change the anchor points and the interior trim on the car.
Old Jan 14, 2012 | 03:54 PM
Car: 1984 T/A
Engine: LQ4
Re: ttops
o ok thanks
Old Jan 14, 2012 | 09:25 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
Re: ttops
both are eom ttops how do you tel if there the c&c tops
Old Jan 14, 2012 | 10:56 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: ttops
Actually there is 3 types. The hook style, the small pin style, and the small pin style with the large plastic sleeve encasing the small pin.
Old Jan 14, 2012 | 11:00 PM
Re: ttops
I think c&c tops are lexan while factory are glass. Not too sure though.
Old Jan 15, 2012 | 08:53 AM
travis401's Avatar
Car: 91 Camaro RS
Re: ttops
c&c tops are all plastic and have a different shape than factory. factory tops came in both plastic and glass.
Old Jan 16, 2012 | 08:10 AM
scottmoyer's Avatar
Re: ttops
I see the spell check feature is still broken on your computer. Come on. Help us out. I just looked at other posts of yours and see that this is pretty common. Is there a reason we should waste our time trying to figure out what you're saying?
Old Jan 16, 2012 | 12:00 PM
Re: ttops
Easy. Remove the interior plastic of the ttop and inspect the plastics for a GM part number which should start with 140*****.
Old Jan 16, 2012 | 12:09 PM
Re: ttops
Correction. My plastic part number is GM 20480375.
Old Jan 16, 2012 | 12:34 PM
Re: ttops
Here are the pics of the part number location....
Old Jan 16, 2012 | 10:23 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
Re: ttops
I had a friend come over and look at a set of glass t-tops I had taken out of a 90 bird.They had the pin that worked by a handle.His 91 rs camaro has a set of plastic tops.The plastic tops have a metal trim running along the edge.to look at the plastic trim there wasn't a visable differance.the seal on the plastic tops exstended further than the glass.the seal on his car was higher than the bird on the interior most side of the seal.Is it possible to use the 90 bird tops on his 91rs,by changing seals or trim?OH,Buy the way,Not everyone is good with spelling.I sure am not.The spell checkers take up alot of time to figure out.My cell phone drove me nuts.Spellchecker even tells me I'm not spelling my last name right.I checked my birth records.Spell checker don't know everything.Give us bad spellers a little slack!
Last edited by Bobby Suth; Jan 16, 2012 at 10:27 PM. Reason: people dont like bad spelling.
Old Jan 17, 2012 | 09:33 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
Re: ttops
the interior plastic of the ttop is not there thay came off a 92 firebird 305 car
my camaro is a 92 v6 car came from van nuts with the plastic ttops but thay are all cracked up when you look throw them the glass tops look close to new and are the pin kind both of them are but the fron of the to the pin in the to its salf is lose and hen the side gaskit were the window meets is short on both sides
Old Jan 17, 2012 | 09:38 PM
Re: ttops
Dude, you need to use proper grammar. Break the sentences. There are too many run-ons. I don't wanna help you with your language arts skill. But if the spelling doesnt matter to you, Ill unsubscribe to this thread.
Old Jan 17, 2012 | 09:42 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: ttops
I haven't seen C&C t-tops in lexan, only glass. I'll add yet another version of t-top to the discussion. There are two versions of C&C t-tops. Most latch similar to the factory version. There is another version of C&C that can flip up in the rear just as many sunroofs do. I have only seen two cars with this style of C&C t-top.
Lon
Old Jan 17, 2012 | 10:17 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: ttops
Measure the length of the glass from windshield portion to hatch portion.
Then measure from a window portion to the roof " T ".
Post your finding.
Old Jan 18, 2012 | 09:25 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
Re: ttops
there the same as the lexan i can text some one a pix of the tops but youll have to text me not sure i want to put my # on here pm me i guess
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
jaysfs
Exterior Parts for Sale
Sep 18, 2015 11:59 AM
MORREALE5
Sep 13, 2015 09:01 PM
scottmoyer
Sep 7, 2015 07:06 PM
Victor6
Aug 30, 2015 02:09 AM
