jack point fix
Old Apr 1, 2012 | 03:28 PM
deadman's Avatar
Car: 89 camaro
Transmission: 700r4 w/ shift kit
Axle/Gears: stockers
jack point fix
on my car all the jack points have collapsed even the place under the fender were it bolts on has collapsed. how do i go about fixing theres ?
Old Apr 1, 2012 | 04:23 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: jack point fix
Thats the problem with these cars, that spot where the fender bolts is NOT a jack point, thats why they collapse. Take it to a body shop and pay them to fix it.
Old Apr 1, 2012 | 05:45 PM
deadman's Avatar
Car: 89 camaro
Re: jack point fix
i really dont want to pay some to do this if its something i can do. exactly what would they do to fix the problem.
Old Apr 1, 2012 | 05:51 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: jack point fix
Im not metal worker but I would imagine after surveying the damage they would opt to cut and replace the damaged portions with straight pieces of metal.
Old Apr 1, 2012 | 05:59 PM
lonesomeloser's Avatar
Car: 1983 Z28
Re: jack point fix
You should be able to straighten it yourself. Grab the metal with some pliers and try to bend it back down so it's straight.
Old Apr 1, 2012 | 06:02 PM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Re: jack point fix
The factory recommended jacking points can't really support the weight of these cars. I have been placing the jack under the LCA's.
Old Apr 1, 2012 | 06:19 PM
deadman's Avatar
Car: 89 camaro
Re: jack point fix
thats what i do as well , the problem is i sold the car a few years back and they decided to jack the car up under the fender an messed up alot of stuff and i bought it back a few months ago and im trying to get it fixed up starting with suspension and thats were i noticed everything was bent up.
Old Apr 2, 2012 | 05:43 AM
Blackknight's Avatar
Re: jack point fix
https://www.thirdgen.org/forums/tech...ng-points.html
Good Illustration where to jack and where to place jackstands. Previous owner of my car crushed the passenger side fender by also jacking wrong. Just cause most other cars can be jacked there doesn't mean all can Well I got new fenders now
Old Apr 2, 2012 | 05:19 PM
deadman's Avatar
Car: 89 camaro
Re: jack point fix
if i wouldnt have sold the car in the first place i wouldnt be fixing anything..... im such a douche!
should i try to straighten the bent parts then fab up a new piece and reinforce the jack point and fender mount and weld everything? i would assume that would be what a body man would do.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
TheTraut88
Sep 11, 2015 05:16 AM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
