T-Tops ???
Old Apr 6, 2012 | 02:43 PM
Justinb2288's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: Formally 3.08/ Now 3.73 Posi
T-Tops ???
So my t tops are blacked out and look horrible. I dont know what kind of material is top of the glass but looks horrible. Should I just use spray paint and paint them?
Old Apr 6, 2012 | 08:35 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: T-Tops ???
Are the glass or plastic?
Old Apr 6, 2012 | 10:01 PM
puma1552's Avatar
Re: T-Tops ???
No. Why the hell would you want to spray paint your T-tops?
The glass is smoked from the factory. I can't imagine how smoked glass could possibly look worse than Rustoleum.
Old Apr 7, 2012 | 07:22 AM
Car: 92 Camaro RS
Engine: 305 TBI
Re: T-Tops ???
like when your inside the car you cant see out of them and on top there faded blacked and looked like cracked paint small cracks everywhere. There is some type of compound or material on top of the glass
Old Apr 7, 2012 | 08:17 AM
mantaguy's Avatar
Engine: 5.0 EFI
Re: T-Tops ???
Just remove all that crap that's on their,put some paint stripper on them.
Old Apr 7, 2012 | 08:54 AM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Re: T-Tops ???
I have some plastic or Lexan that are all scratched and I thought about painting them body color but painting glass would not really look good nor work well.
Old Apr 7, 2012 | 09:56 AM
puma1552's Avatar
Re: T-Tops ???
Agreed, remove the crap, rather than piling more crap on top.
Old Apr 7, 2012 | 10:19 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: T-Tops ???
Sounds like you have the plastic ttops. They are known for doing that. If you can swing it, buy some glass tops...
Old Apr 7, 2012 | 05:09 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: T-Tops ???
I got a set of TTops for sale!!!!
Old Apr 7, 2012 | 09:51 PM
KuroNeko's Avatar
Car: 1986 Firebird, 1992 camaro
Engine: 79' 350, 89 305
Transmission: TH400, 700r4
Re: T-Tops ???
does it look like this?
if it does, theres no hope for it, i tried everything, i just ended up going to the junkyard and got a pair of glass ones for 40$
Old Apr 7, 2012 | 10:09 PM
TTOP350's Avatar
Re: T-Tops ???
There is a thread on one of the corvette forums about them wetsanding and buffing the plastic tops.
Old Apr 11, 2012 | 03:12 PM
Car: 92 Camaro RS
Engine: 305 TBI
Re: T-Tops ???
yeah thats them lol...so thats why I was saying maybe spray paint matte black
Old Apr 11, 2012 | 07:15 PM
Eleanor62's Avatar
Re: T-Tops ???
Old Apr 14, 2012 | 02:12 AM
tlandoe's Avatar
Car: 1983 camaro z28, 1981 honda cb650
Engine: Lu5 305 crossfire v8
Axle/Gears: 2.93
Re: T-Tops ???
craigslist. There's always someone selling a pair of the glass ones for a hundred or so. They are heavy, but better than paint
Old Apr 14, 2012 | 05:10 AM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: T-Tops ???
hey guys Ive also got crappy plastic or lexan t-tops and wouldnt mind replacing them and I definitely like the idea of the glass t-tops but will just any t-tops from these cars work? Ive got a 91 z28, thanks for your rply guys
Old Apr 14, 2012 | 10:09 AM
tlandoe's Avatar
Axle/Gears: 2.93
Re: T-Tops ???
Yes and no. There are three types of ttop strikers in our cars that vary through the years. This includes the latches (82-83) the 5/8" pins (83-89) and the fat pins that are bigger than your thumb (lexan ttops). The fat pins are just the 5/8 with a plastic shroud around them and they do fit the regular round ttop striker receiver found on most cars. Not exactly sure if they are interchangeable, but they should be. The latch style are totally different and if you come accross them, leave them alone, they won't fit.
Old Apr 14, 2012 | 11:27 AM
KuroNeko's Avatar
Re: T-Tops ???
i have a 92 and the glass ones i got fit just fine, even the t-tops on my 86 fit on it just fine, just go to a junkyard and see if they'll let you test fit them, thats what i did
Old May 19, 2012 | 01:57 PM
jmcmillanjr.'s Avatar
Car: 1991 T/A GTA, 1991 T/A
Engine: 350 and 305
Re: T-Tops ???
I also have the crappy plastic latch type ones, I was thinking of trying and restoring them as it would be cheaper than buying a new set or should I go with the glass ones and if so what would be an adequate replacement?
Old May 19, 2012 | 04:11 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
Re: T-Tops ???
I betcha that mequiars headlight restorer would work
Old May 21, 2012 | 10:59 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: T-Tops ???
This is not a bad idea, but you can also wet sand with say 1500 grit, then work to 2000 grit then buff the hell out of them. I have the glass tops and would not dream of having the plastic ones.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
