windshield wiper blade removal
hey guys. im really embarassed asking this but how to you remove the wipers on my 84 camaro? I knew how to do it on my mercedes cause it had a hook at the end that just kindof latched in. but the camaro has like a bolt or stud or something going through the side of it holding it in place. how do i remove this thing? I thought american cars were supposed to be easier to work on. lol
Car: 1987 Trans Am
Engine: LQ9/L92
Re: windshield wiper blade removal
if yours are the original style pin setup (and not the universal replacement style clips), there should be a little metal spring in the center. use a small pick or flathead screwdriver to slide spring while pushing the wiper away from the arm
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Different wiper blades lock the pin style differently. Some you can just pry off, others have a spring clip that you need to pull up to clear the edge of the retainer.
Or start here @ 2:10 below.
@0:35 sec they show it being pried off. I guess you have to click the link below and then click on the box that says "pin arms" at the bottom in order to see the video.
http://www.carid.com/images/rain-x/i...tallation.html
I had the same problem when I tried to replace the wiper blade and assembly.
I bought refills instead. It is a lot cheaper.
Replacing entire assembly and blades is about $25.
Replacing just the rubber wiper blades is about $5.
Car: 1983 Camaro Z28
Engine: 350 Carb
Axle/Gears: 323 Posi
I know this is an old thread, but I just wanted to post some info in case someone is searching for this topic. I had the original wiper blades on my 83 camaro (side pin type) and found that the key to getting them off was to spray the pin area with some WD-40 and then wrap some tape around a wide flat screwdriver blade. A quick twist with the screwdriver between the blade and the head of the wiper arm and they popped right off.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I had a hard time finding universals at the parts store that mounted right!
Wanted some fancy new style ones (like these: link) but couldn't get them on there!
Axle/Gears: 10 Bolt 2.73 Open
From: Michigan [Bodacious Member with the Bodacious TA'TAs (Trans Ams)]
Car: 91 Formula - Authentic and REAL
Engine: 5.0 Liter
Some of the older wiper frames had a LITTLE tiny square recessed tab on the top instead of the plastic snap. You use a small screw driver to pry the tab up to lift the clip off the pin and slide it off.
Bohemian
Aug 15, 2017 05:11 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
