foam spoiler fiberglassing
Old Apr 23, 2012 | 02:34 AM
buzzthefuzz's Avatar
i have a 1986 trans am with 222,000 miles on it and its in needs of some repair. the rear wrap around foam spoiler is very deteriorated, and one of my buddies suggested fiberglassing over the spoiler and molding it into the rear hatch. im not very experienced with car body work, but i thought now might be a good learning opportunity, not to mention my cars white and it would look better if the spoiler was painted the same color as the car.
would the best option be to remove the glass from the back metal part of the hatch and mold the spoiler to the metal section? id have to do something about securing it back to the glass, all the clips are in pretty terrible shape.
im not sure what kind of prep would be needed in order to prevent cracking or how hard its going to be to make straight, so any and all advice is welcome, was just looking for other options than dropping $400 on a new one.
Old Apr 23, 2012 | 11:14 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: foam spoiler fiberglassing
Before you go and spend a lot of money and time on your project,we are having a group sale on brand new fiber glass wrap around spoilers,check it out in the bodt thread.We need a couple more members to commite to get the discount.
Old Jun 23, 2013 | 07:34 PM
I felt like this thread deserves a bump... I'm just looking for advice as to the best course of action, I'm not really in a rush
Old Jun 23, 2013 | 09:41 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
unless you can clean and prep the metal frame that's inside the orig wing your going to keep having the same issue of it splitting and such. mine lived in a garage for the past 8 years and the part that mounts to the deck separated from the wing and I knew it was time to purchase a glass replacement.
Old Jun 24, 2013 | 02:15 PM
mantaguy's Avatar
Engine: 5.0 EFI
In the long run,you'll save a lot of time and money.
Old Jun 24, 2013 | 05:44 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Thats depressing... Here in Wisconsin its nearly impossible to find a used one in nice shape and new costs a boat load. I might end up going with the older style straight across spoiler. Those are dirt cheap and don't really go bad.
Old Jun 24, 2013 | 07:45 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
you will need the whole hatch or swap just the deck panel unless you are good at drilling the holes where the wing will be straight but it is an option.
Old Jun 24, 2013 | 08:36 PM
mantaguy's Avatar
Engine: 5.0 EFI
Does't matter where you live,your not going to find an original wrap around spoiler in good shape,unless it's it's been inside for 25 yrs.
Old Jun 24, 2013 | 10:35 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
My understanding is that the metal spoiler frame rusts and pushes out on the rubber causing cracks. I always wondered if southern cars didn't have this problem... i guess they do.
Its a shame, the wrap around spoilers look so much better in my opinion.
Old Jun 24, 2013 | 11:19 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
that's exactly what happens. when I got my FORMULA the wing looked good from the front and sides but had 2 splits on the pas side and 1 on the dr side at the back. it was my daily for the first few years and would reside outside and then I go my S-10 and the FORMULA sat with a light weight car cover outside.
when we moved the car has stayed in the garage for the past 8 years and developed a crack on the top of the wing and started to get a bit distorted. if GM protected the metal I think the wings would live a little longer. my car is a southern car and yup, its bad down here as well.
this was one of the best big purchases iv made for my car. nothing like hitting the hatch popper and the hatch raises on its own.
Old Jun 24, 2013 | 11:32 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Put a '97 wing on mine. No regrets. Saved 20lbs. probably.
Attached Thumbnails foam spoiler fiberglassing-dsc00592.jpg   foam spoiler fiberglassing-dsc00531.jpg   foam spoiler fiberglassing-dsc00613.jpg
Old Jun 24, 2013 | 11:40 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
I do love 4th gen wing but I thought the centerposts weren't long enough to touch the hatch? Am I wrong..? It looks like yours sits on there nicely.
Old Jun 25, 2013 | 02:07 AM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
I thought the centerposts weren't long enough to touch the hatch? YES
It looks like yours sits on there nicely. YES
In these two threads I show how it's done.
https://www.thirdgen.org/forums/body...ody-paint.html
https://www.thirdgen.org/forums/body...n-wing-my.html
Old Jun 25, 2013 | 09:17 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
WOW that is nice paint job you had done there. I might attempt the 4th gen spoiler over the winter, it looks doable. Thanks for the link Does anyone know how much those spoilers are sold for?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
F-body-fan
Nov 4, 2015 06:13 AM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
