TA fender vents
Old May 8, 2012 | 09:22 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
TA fender vents
what are the vents in the fender for? the ones i have looked at dont really vent any thing.
Old May 8, 2012 | 09:31 AM
82tarecaro's Avatar
Re: TA fender vents
For looks - that's it
Old May 8, 2012 | 09:38 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: TA fender vents
Purely cosmetic pieces, just like the hood vents.
Old May 8, 2012 | 10:49 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: TA fender vents
Can't you make these functional, say for example, brake cooling?
Old May 8, 2012 | 10:53 AM
82tarecaro's Avatar
Re: TA fender vents
Possibly. I wouldn't see the point unless you road race.
Old May 8, 2012 | 11:04 AM
Car: GTA
Re: TA fender vents
For brake cooling, you just need air inlets from the nose blowing onto the back of the rotors. The heat would blow out & through the wheel.
Old May 8, 2012 | 02:14 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
Re: TA fender vents
thanks...im going to put them in the hood behind the radiator...make heat extrators out of them.
Old May 10, 2012 | 09:02 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
Re: TA fender vents
they function now...lol not sure how much heat they will extract but its got to be better than nothing.
Old May 10, 2012 | 09:20 AM
Car: GTA
Re: TA fender vents
Between the air pressure from the air dam pushing air up into the engine compartment & air flowing over the hood creating a slight "suction" effect? Those will work, assuming that there is a hole all the way through the hood under them & not just through the outer skin of the hood (i mean that the inner bracing is cut out too).
Old May 10, 2012 | 12:05 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Re: TA fender vents
I think those would look pretty good without the stick on cowl.
Old May 10, 2012 | 01:56 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
Re: TA fender vents
the holes do go all the way through the hood and inner bracing.
you dont like my cowl, nick? you would laugh if i told you what it really is.
Old May 10, 2012 | 05:10 PM
Engine: LB9, LS1
Re: TA fender vents
Please share.
Old May 11, 2012 | 08:47 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
Re: TA fender vents
Originally Posted by _Nick_
Please share.
pm sent
Old Oct 7, 2020 | 06:50 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Re: TA fender vents
Bumping this as it's the only post about it I've found and I wanted to clear something up.
The fender vents are 100% functional as shown by the dealer brochure.
Old Oct 7, 2020 | 07:41 AM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
Re: TA fender vents
that's correct! they do vent under hood- hot air. the second gen's being higher up on the fender you could reach out and feel the heat venting
Pac J
May 17, 2020 10:44 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jovibuilt
Oct 18, 2015 08:12 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
Fanatic1074
Oct 2, 2015 03:47 PM
