1985 Trans Am T-Top Restoration Completed
Old 05-10-2012, 12:46 PM
1985blktransam's Avatar
Car: 1985 Firebird Trans Am
Engine: 5.0 Liter Engine
Axle/Gears: 3.08
T-Tops look great, but when issues arise, no one will touch them in NJ. I just had the T-Tops Restored back to Original GM, New GM Center Bar, GM weathertipping around the body (New Revised Version) and T-Top on both side. New GM Drip moldings, the works.
Biggest Obstacle was Rust under the Center Bar and Weatherstrips. Jeff at East Coast T-Top is a Former Body and Paint guy, so no problem to fix and repair.
Car was in the shop for a week. If you have T-Top issues, go to East Coast T-Top in Bristol, PA, his expertise in T-Tops is amazing. Check out his site
http://www.eastcoastt-top.com/index.html
See some of the Pictures of the Rust on my 1985 Trans Am.
Note: I had the T-Top Center Bar that I bought years ago, so he used that one. The Center Bar is Discontinued and very hard to find. There are alot of used ones out there, eBay, just be careful what you buy.
Jeff at East Coast T-Top will use your Parts if GM, so that can save you some $$$$$$
Attached Thumbnails 1985 Trans Am T-Top Restoration Completed-85ta-4.jpg   1985 Trans Am T-Top Restoration Completed-85ta-5.jpg   1985 Trans Am T-Top Restoration Completed-85ta-6.jpg
Old 05-10-2012, 12:52 PM
Axle/Gears: 3.08
Re: T-Top Restoration Completed
Here are some more pictures with Rust Cleaned up
Attached Thumbnails 1985 Trans Am T-Top Restoration Completed-85ta-10.jpg   1985 Trans Am T-Top Restoration Completed-85ta-12.jpg   1985 Trans Am T-Top Restoration Completed-85ta-15.jpg
Old 05-10-2012, 12:59 PM
86blackbetty's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305/V8
looks great...i have the same problem..for that reason i dont take of the ttop..i luckily have the ttop bar row..i hope i dont have rust on the edges or under the weather stripping. if i do then i guess i might have to head over to PA
Old 05-10-2012, 01:08 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: 1985 Trans Am T-Top Restoration Completed
How much was it?
Old 05-10-2012, 02:38 PM
Axle/Gears: 3.08
Well, it was not cheap by any means !! Like I said, there is no one who will touch T-Tops in my area, so it needed to be done. It was 2 Grand total and there for a week. Plus $400 for the Rent a car since Bristol was 2 Hours away from me.
Alot of man hours on the Rust, plus the GM parts. I had some of the parts, Center Bar and the weetherstrips that go around the car, but they were the 1st design, so no go.
He had the 2nd Design GM weatherstrips to prevent Leaking. When you change them, you also need to change the Weatherstrip in each T-Top as well, then the drip Molding,so it was quite involved. He also had to adjust the windows since they were too low and cause wind noise.
Mine was pretty bad, so I expected it to be pretty high. Not everyone will need all that work and will be less expensive
Attached Thumbnails 1985 Trans Am T-Top Restoration Completed-85ta-16.jpg   1985 Trans Am T-Top Restoration Completed-85ta-17.jpg
Old 09-01-2014, 08:54 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
I wish there was a guy like this in Boston
Old 09-01-2014, 09:26 PM
siguy2k's Avatar
Replaced bar or fixed? Where did you pick up the replacement if so?
Old 09-02-2014, 06:11 AM
KITT1983's Avatar
hawksthirdgen has new 85-92 ttop bar
Old 09-02-2014, 12:45 PM
Axle/Gears: 3.08
The Center bar I used was New GM that I bought years ago, GM Part 10092095. The Center T-Top had 2 designs, one with the T-Top Channels for 1982-1985 models and 2nd design for 1986 and newer. These are the GM Part Numbers if that helps. I converted to the 2nd Design since My 85 TA did have the Plastic Channels on them, purchased New T-Tops to go with the New Center Bar. It looks much cleaner with just the glass.
GM PART # 20192907 - Center Bar 1st Design forPlastic Channels
GM PART # 10092095 - Center Bar 2nd Design No PlasticChannels, just glass edges
You can still look for New GM, but very difficult to find. The other option is a good Used one which are plentiful, just ask many questions before you buy anything. I have heard good things about Hawks Center bar.
Hope this helps
Old 09-21-2014, 06:17 PM
KITT1983's Avatar
I called that guy at east coast ttops and I am impressed. I will use him in a worse case scenario.
Old 09-21-2014, 06:42 PM
KITT1983's Avatar
Hope this helps
Thanks I was told there is no difference between the two.
Old 09-22-2014, 04:18 PM
knight72's Avatar
Car: 1992 W68 Firebird
Engine: 305 5.0L V8 TBI
do you have pics of both bars so we can compare?
my 92 bird came with lexan ttops. any chance my car has the 1st version of the ttop bar?
Old 09-22-2014, 04:30 PM
knight72's Avatar
i have glass ttops now.. they look look this:
i know i have to replace the weatherstripping, but i don't think that's the problem.... or maybe it is?
Attached Thumbnails 1985 Trans Am T-Top Restoration Completed-20140922_172420-1-.jpg   1985 Trans Am T-Top Restoration Completed-20140922_172328-1-.jpg
Old 09-24-2014, 11:05 AM
Former Sponsor
1Aauto's Avatar
He did a great job on that T-Top bar. Looks good!
Old 12-13-2014, 04:48 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
That's awesome, I need to do the same thing.
Old 04-17-2015, 09:50 PM
pir8fox's Avatar
Car: 1985 Trans Am
Transmission: 4 speed auto
Axle/Gears: 9 bolt posi
Anyone know where to get the two seals that are on both ends of the t-top bar underside that cover the holes?
Old 04-17-2015, 09:56 PM
pir8fox's Avatar
Car: 1985 Trans Am
Where can I find the two seals that are on the underside of each end of the t-top bar?Bought new seal kit to replace the old ones and am replacing t-top bar due to rusty outside edge lips,discovered there were seals on the underside of each end of the t-top bar.Can I just use silicone sealant instead to make new seals?
Old 04-19-2015, 08:49 PM
KITT1983's Avatar
Do you have any pictures of the area you are talking about?
Old 04-20-2015, 07:56 AM
Former Sponsor
1Aauto's Avatar
Do you need the seal that goes up the A-pillar under the T-top glass, and then back down the B-pillar ?
Old 04-26-2015, 07:50 AM
KITT1983's Avatar
got a photo ?
Old 07-12-2018, 06:46 PM
KITT1983's Avatar
Any updates ?
Old 07-13-2018, 09:40 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
Does it still leak after all the work? I had my seals replaced years ago and they still leaked during heavy downpour.
Old 09-15-2018, 08:26 PM
KITT1983's Avatar
does it leak ?
Old 09-17-2018, 09:58 AM
Axle/Gears: 3.08
No leaks after the work was completed at East Coast T-Top in Bristol, PA. Was at the Carlisle show where it poured rain, my car was completely dry. My buddies in there 89 TTA had a lot of water leaks. Jeff at East Coast T-Tops is amazing. He installed the GM Second Design Rubber Stripping. He had the Last 2 in Stock when I had it done back in 2012.
Since then, my buddy had his TTA done at East Coast T-Top and has no leaks as well.
Hope this helps
Old 05-01-2021, 01:16 AM
KITT1983's Avatar
It looks like I have to go to him
https://eastcoastt-top.com/t-top-service
vdoggie
10-14-2013 05:22 PM
deeznuts94
04-23-2013 02:16 PM
BlueZee28
Exterior Parts for Sale
18
02-10-2011 09:43 PM
Beachhead
11-12-2005 11:50 AM
StocRoc
04-27-2004 01:01 PM
Quick Reply: 1985 Trans Am T-Top Restoration Completed
