Shifter Knob
Old Nov 17, 2000 | 06:41 PM
SGT SWEETPANTS's Avatar
Shifter ****
I have bought an after market shifter **** for my five speed but have run into some difficulties in installing it. The threads on the inside of the new **** are considerably smaller than the threads on the shaft. If it were the other way around, I could got the hardware store and buy a fitting, that simple. BUt, of course, that is not the case. The **** it self is a hard plastic with a metal piece inside of it with threads so tapping it out is out of the question. The **** it self if transparent and is black on top with flames on it and has a fiber optic light that goes into it and I am having serious difficulty waiting to see it in my Iroc. Thanks in advance for any help.
Pimpin' ain't easy.
Old Nov 17, 2000 | 07:49 PM
dudelovett's Avatar
I had the exact same problem trying to put a Hurst T-Shift **** in my old Firebird...i found the best thing to do is to stay stock..after all, its just a shift ****, not a shifter, so its not really doing anything.
1991 Firebird Formula, 305, TPI, Auto...stock till I get some money!!!
Former owner of an 88 2.8 Firebird....RIP
Old Nov 19, 2000 | 10:47 AM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
just cut the stick and fabricate the screw end you need,you might need to remove it from the car and weld it or,if your really lazy, just throw down a blanket and do it right in the car(cutting it could be messy),I know how you feel,when I have a trick piece for my car,cosmetic or performance I want in on period. I stop at nothing.
Old Nov 19, 2000 | 02:37 PM
ONEFINE8T9's Avatar
hey if that shifter **** doesnt work out get a new 2000 trans am or camaro 6 spd ****. The one for the hurst shifter. It sits lower than factory giving a shorter throw and its leather wrapped so it looks kool to. It is a pistol grip style and it has a kool "H" for hurst on top. It went right in for me no problems. U could get this from the dealer for a decent price or just find a wrecked 4th gen with the **** still there. It just spins right off
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
system: 2 10" MTX thunder 2000 in a Professionally done custom bandpass box.
Blaupunkt CD player
Blaupunkt 4x6 and 6x9
600 watt rockford fosgate 4.6 amp
thinking about a flowmaster
Old Oct 31, 2009 | 05:56 PM
entrig00's Avatar
Car: 91 Camaro RS
Engine: 3.1 V6
Transmission: t-5
After market Shifter **** wont fit...
LOL...ya ya I know this thread is very old so sorry to bring the dead back.
By the way I did a search, alot and didnt find anything except for this one and only thread...try it before telling me to search lol....ok that takes care of that lol...
I'm having the same problem but my shifter **** is a B&M and all metal...should I try and make the hole wider to fit in ?
Anyone please and if you done this some info and help would be great...
Thanks people....
Old Oct 31, 2009 | 06:29 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: After market Shifter **** wont fit...
I'm running the B&M Hammer shifter without difficulties on my T-5.
JamesC
Old Nov 1, 2009 | 01:43 PM
entrig00's Avatar
Car: 91 Camaro RS
Engine: 3.1 V6
Transmission: t-5
JamesC
you must have the whole kit, shifter,base and all. Can you post a pix just to check out and get an idea? I didnt think of doing the hole b&m shifter, I was just trying to screw on the **** lol....
where can I get one like yours for our gen camaro?
Thanks....
Old Nov 1, 2009 | 03:06 PM
JamesC's Avatar
IIRC, the Hammer shifter is threaded for the OE T-5. It can be purchased from Summit (and probably Jeg's):
http://www.summitracing.com/parts/BMM-80742/
A pic can be seen in my Car Details below.
JamesC
Old Nov 2, 2009 | 04:18 PM
entrig00's Avatar
Car: 91 Camaro RS
Engine: 3.1 V6
Transmission: t-5
JamesC
I have the other B&M shifter that didnt fit the thread. its the one with red on the background of the b&m.....so yours fit the lever or metal rod?
Old Nov 2, 2009 | 04:29 PM
JamesC's Avatar
Because the OE threads are the same as the threads on Hammer (M16 x 1.50mm), the Hammer will fit the OE shifter without an adapter insert.
The "Check Application" on the thread above will provide more info if you need it.
JamesC
Night rider327
Feb 25, 2016 09:50 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
