Speedometer grinding?
Old Dec 5, 2000 | 03:26 PM
AAustin50's Avatar
Noticed loud noise from speedo on the way to work this a.m. and the needle started jumping erratically. Reset trip meter and the noise stopped and needle ok. Then it started grinding again. It sounds like the gearing inside the speedo is self-destructing.
I want to disconnect the speedo cable behind the gauge until I have time to look at it. What's the easiest/quickest way to get to it? Do I have to pull the entire cluster out? Any special tools needed?
Thanks in advance.
'87 Camaro RS
2.8/4-speed Auto
Old Dec 5, 2000 | 03:33 PM
evilho7810's Avatar
It might just need to be lubed up.
Old Dec 5, 2000 | 04:12 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes. No.
Old Dec 5, 2000 | 07:00 PM
AAustin50's Avatar
Will try the lube first-maybe the cold weather is causing it to bind.
Thanks again.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
