KEYS A,B,C,D,E ???
Old Nov 26, 2000 | 02:33 PM
SIMON HOLTBY's Avatar
KEYS A,B,C,D,E ???
I am trying to get a spare set of keys cut here in the UK and not having much luck.
No locksmiths keep the blanks but an american parts supplier does but he needs to know if it is an A,B,C,D,E blank. It is too long a journey to visit him. He says this letter is stamped on the key but it is not on my ignition key but is on the key for the doors and is a 'D'. The ignition and fuel cap keys are different blanks.
Please can anyone with a car manufactured in 1988 tell me the letters printed on your 3 keys and the month of manufacture of you vehicle mine is 11th July 1988.
I dont think this will compromise your security but do not list any numbers on the keys, if there are any.
Thanks in advance for any replies.
Simon Holtby
88 Camaro 5.7 Z28 TPI etc
Old Nov 26, 2000 | 05:31 PM
SGT SWEETPANTS's Avatar
I have an '86 and I don't know if the key type would have changed within those two years (I doubt it) and my ignition key is "A" and the door/trunk key is "B". Hope this helps.
'86 IROC-Z
305 LG-4, T-5
T-Tops
50k Original Miles
K&N Air Filter
Stage I Chip
KYB Shocks/Struts
Centerforce Dual Friction
Old Nov 27, 2000 | 03:33 AM
Omar's Avatar
My door says "D", and nothing on my ignition key. Sorry.
1989 IROC-Z 5.7L
Old Nov 27, 2000 | 05:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Each year they change from one set of blanks to another. They use the same blanks across the whole GM product line in a given year. An 83 is A ign & B doors; 84 is C-D; 85 E-F; etc. J-K is as far as they go, then they start over. Your car was actually almost certainly built as an 89 with a production date that late, so it will have C-D blanks, unless somebody has replaced the ignition cylinder; nearly all of the replacement those are As.
In any case only one of them will even go into the lock. All you have to do is take one of each blank and try it; the one that fits is the right one. Too complicated for a locksmith I guess.
Old Nov 28, 2000 | 02:37 PM
Thanks for the replies so far. If keys are grouped AB,CD etc then as my door key is a D it would suggest that the ignition is a C although this does not match 'SGT SWEETPANTS' reply. But only his year does not match not the pattern of AB, CD ....
I'll wait to see if I get any more replies but C and D blanks look favourite at the moment.
Simon
Old Nov 28, 2000 | 02:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Do you mean calendar year or model year? My 84 has A & B keys.
1984 Silver Z28, decked 383 cid 4 bolt, ARP Fasteners, 2 1/2" Cowl Induction Hood, 600 cfm Performer Carburetor, Torker II Intake, Performer RPM Heads, XE268H Cam, Magnum Roller Tip Rockers, MSD6AL Ignition, Blaster2 Coil, Recurved HEI Distributor, 700R4, TransGo SK, 2.73:1 Limited Slip Dana 44, Terminator Headers, Custom 3" TIG Welded Stainless Exhaust, Flo-Pro Twister Muffler, 4 Wheel Disc Brakes, Oil Cooler
Old Nov 28, 2000 | 07:57 PM
91FastBird60kmiles's Avatar
Hey man, ive worked at a hardware store for 3 years and have been making keys since i started there.
If ur door key is "d" then ur ignition is "c".but, if it has the "vats" chip on the key u have to go to a gm dealer to get that made.
Old Nov 29, 2000 | 03:11 PM
I'll order C and D blanks tomorrow thanks for all your help.
Simon
88 Camaro 5.7
Old Nov 30, 2000 | 12:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
My '86 also has "A" & "B", like SGT Sweet's...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Dec 19, 2000 | 08:10 PM
812MANY's Avatar
VATS didn't start until the 90's in F bodys. (91 I think)
Old Dec 19, 2000 | 08:49 PM
Omar's Avatar
VATS started in 89 for F Bodies.
1989 IROC-Z 5.7L
Old Dec 19, 2000 | 11:58 PM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
no not necessaraly so... i went round the corner to a hardware store and got my vats key made. i think it differs from one place to another.
I have experience...unfortunatly,its a result of bad judgement.
click below to check out MY FORMULA PAGE!
http://www.formula350.com
or click below to email me
astralbaby11@hotmail.com
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
