Decal Removal
Old Dec 24, 2000 | 04:39 PM
ede's Avatar
ede
Decal Removal
not on a thirdgen, but i figure it's all the same. my jimmy has a decal stripe ,about 4" tall, along the bottom of the body and across the front and rear bumper covers. i tihnk it'd look alot better without it. can i remove it without hurting the paint under it? i know there is decal removers but the ones i've saw seemed pretty harsh and i was afraid it's hurt the paint. if it matters it's black. any ideas or experiences? thanks
ICON Motorsports
1st & 3rd
Old Dec 24, 2000 | 09:12 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
If it's like a sticker, sometimes you can just take a blow dryer and warm it up for a little bit, then pill it right off. That's just a guess though. No experience talking here!
Old Dec 25, 2000 | 12:11 AM
Tonyrodz's Avatar
Transmission: auto
Don't even waste your time w/a home hair dryer--tried that w/my Formula, tried to take the lettering off the door--took forever! Better off using some kind of industrial type heater(dryer)just don't hold it too close or for too long. Removed mine w/a body shop type.
Old Dec 25, 2000 | 07:56 AM
sheet outta luck's Avatar
on my truck i took all the stickers and emblems(stuck on with double sided tape) off by soaking them with warm soapy water for a while, then used a plastic card like an ID or credit card to slowly and carefully scrape them off(while continuously pouring soapy warm water with a sponge on the area) and I removed all left over residue from the stickers or tape by rubbing the area with a clean terry cloth and a very good reliable car wax. I used Prestone Bullet Wax. It was a quite slow process, but left no marks or scratches. But if you scrape the card at the wrong angle, you might leave small hairline scratches.
Old Dec 26, 2000 | 05:54 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
The best and only, non-damaging way to do this is really fun!! Can't think of a better way to spend my weekend!! Let a couple of fingernails grow a little and keep at it. No matter how bored or upset you get. You'll only get about 3mm at a time, but if you don't want to repaint.....
Try all other methods, but I believe that you'll find this to work the best.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Old Dec 26, 2000 | 10:37 AM
Mike 25th's Avatar
NO WAY!
The 3M decal remover does seem quite harsh for paint, BUT I have used it numerous times because I am amazed with how well it works. I took all the decals off of my white truck a few years ago and it looks great still! I took some decals off of my black Camaro too, and that still looks great. Decals curl right up and peel right off, NO EFFORT whatsoever. You won't be dissappinted, TRUST ME.
92 Z28 - 5.7 - Black/Grey Leather
Macewen White Faced Guages
SLP T-RAM, 24lb/h Injectors
Accell 52mm Throttle Body
SLP 1 3/4" Headers and Cat Back Sys.
One Awesome Camaro Site!
Old Dec 26, 2000 | 04:09 PM
Coolcars's Avatar
Originally posted by Mike 25th:
NO WAY!
Gotto agree on this one, I buy several company vehilces each year and they are all covered with logo's and numbers and the commercial removers 3M and others do do the job without hurting the paint. Be careful though depending on the color of the vehicle you may have noticable paint fading. The process still takes some time. I would say you might spend 4 to 6 hours removing all of the stickers off of a camero Z28 or Trans Am
2E,87 Formula 350,with coolant bypass and 160 thermostat and chip. 1986 Z28 with 327 & 202 heads and 5 speed, and usually 4 or 5 others Camaro's & 3 Firebirds to fix, Drive, or sell.
Old Dec 26, 2000 | 06:31 PM
dirtball85's Avatar
A paint stripper heat gun type thing works
quite well.
Old Dec 26, 2000 | 07:34 PM
theformula's Avatar
Ede, hit it with a hairdryer then apply some Goof -off. I've used goof -off on fresh unwaxed paint and it did no damage.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom cold air intake w/K&N, SLP airfoil, ported plenum, TB coolant bypass,Crane AFPR (47psi),94 octane,Crane Extruded Alum. 1.6 full roller rockers, Timing set from 4*BTDC to 10*BTDC,MSD6AL, Holley 9mm Annihilator Laser shot 50 wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, SLP 1 5/8 headers,SLP catback,3:73s,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Street legal with stock throttle body, runners,intake manifold,cam, and heads. Coming next..9# Procharger!
Old Dec 27, 2000 | 12:21 AM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
Worked at a dealership for a while, and the trick we used to take old decals off was quite simple. We had a big round chunk of rubber we attached to a drill and used it as an eraser. The decals just rubbed right off, and the rubber came off no problem. Easy and quick, no damage.
Take 'er easy, and if
she's easy, take 'er twice!!!
Old Feb 16, 2001 | 08:25 PM
dudelovett's Avatar
I'm going to be removing my decals tomorow
Where can I get the 3M stuff??
Old Feb 17, 2001 | 09:49 AM
Chuck Everly's Avatar
Ede, Use a hair dryer to heat the decal as you are pulling it off. No chemicals needed. It worked for me.
Old Feb 17, 2001 | 01:43 PM
buddman91rs's Avatar
soak the decal in WD 40 then take a credit card or the like and scrape it off. my dad just brought a new truck and took the dealer stickers off doing it this way and i've taken the dealer stickers off of my 91 RS using the same technique. very inexpensive and doesn't hurt the paint one bit. if it helps the truck is white and silver(took off black stickers) teal green 'maro wit white stickers.
1991 RS LO3
mods: 14" chrome air cleaner, straight-piped after cat exhaust with one chrome dual tip on the left side.
future mods: headers, removing smog equipment, and as many cheap mods as i can find
aol s/n: budman8503
Old Feb 17, 2001 | 06:17 PM
RS'er's Avatar
You guys are all insane. Use a FRESH Razor...Take your time and just scrape the decal off. Do it at a shallow angle or else youll bite into the paint.
Thats 20 yrs of experience in the auto restyling trade talking.
Old Feb 17, 2001 | 06:29 PM
combined experience from the people i got my tip from....70 years from my grandad, 20 years from my dad and i was helping my dad take off the 'maro stickers when i was 10 which makes five for me(working on friends cars)so uh razor my *** j/k man it's all good it's up to the guy whos going to do it to his car
Old Feb 17, 2001 | 10:28 PM
dudelovett's Avatar
Well, I just did mine and I used a paint scraper and a blow dryer. Took me an hour to get all the birds, 5.0 decals and the Formula letters off my car. Left some glue, but that came off with some hot water and an SOS pad. I cut into the paint nicely on one spot, but it doesnt matter because the cars going in to get painted on Monday!
Old Feb 18, 2001 | 11:18 PM
82 TRANS AM's Avatar
Car: 82 T/A WS7
Engine: Pontiac 400
Transmission: Muncie 4-speed
ede, There is one good response so far and that's Hummer. It's called a stripe eraser. It attaches to a drill. It's easy and fast. Will not damage your paint. Do not use chemicals or a razor. 20 years experience and someone still uses a razor? That person must crap in an outhouse too. 3M makes one but i think the other 3M posts are talking about the chemical spray and that's out. Very messy and toxic as hell. Any body shop supply store can set you up. About $20.
Kenney
82 Trans Am WS7 notchback
83 Trans Am WS6 T-tops
72 Vista Cruiser 455
90 Olds Trofeo
80 K-10 w/snow plow
Painter @ Chevy dealer
GM junkie
Old Feb 20, 2001 | 08:28 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I've heard of alot of people useing the eraser style remover myself...but i've never had to attempt this so i wouldn't know..
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Problems every other day with the car (probably not a mod, but to me it sure makes a difference)
Old Feb 21, 2001 | 12:42 AM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
use the eraser i had a buddy do this when we removed the side moldin off of his ram worked great
1983 CHEVROLET CAMARO with a 1986
305 C.I.D.V8 BORED .030 OVER
HIGH VOLUME OIL PUMP
FLAT-TOP PISTONS
MILD CAM
3" CAT BACK EXHAUST W/ FLOWMASTER MUFFFLER
KEYSTONE CLASSIC WHEELS.
B&M RATCHET SHIFTER
STAGE THREE SHIFT KIT
(she'll spin em into third)
CHECK OUT MY SITE <A HREF="http://www.fbody.com/members/bigdaddyshawn/
MUSTANGS" TARGET=_blank>http://www.fbody.com/members/bigdaddyshawn/
MUSTANGS</A> SUCK
Old Feb 25, 2001 | 12:15 AM
IROCKZE's Avatar
Car: 85 Mercedes 500SEL
Engine: 5.0 DOHC
What about those clay bars? I used one to get bits of tar and tree sap off and it was amazing.
85 IROC,5.0 TPI,T-Tops,fully loaded,black with red Lear-Siegler "Camaro" interior,Decal Delete,91 Bose stereo,Stage 2 Fastchip,AFPR,TB Airfoil,K&Ns,March pulleys,Alum. Driveshaft,92 police version 700r4
"The Devil drives a Camaro"
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Stroopwafel
Sep 11, 2015 06:38 AM
pimprs
Sep 10, 2015 03:34 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
