Can a power trunk release ?????
Old Mar 26, 2001 | 04:20 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
I have a 86 TA with the power trunk motor that pulls down the hatch when u close it & i was wondering if its posible to add the power trunk release button and solonoid with the option i described above?
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 liter h/press. walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
Old Mar 27, 2001 | 12:39 AM
86ZRICHIE's Avatar
yep, mine has the selanoid on it, not functinal yet though. You may need to add some wiring for the switch, but it's nothin difficult.
Old Mar 27, 2001 | 12:42 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Yep. My RS has that option from the factory.
'68 Camaro Vortec 350
'91 Camaro RS TBI 305
I used to have a Z28!
Old Mar 27, 2001 | 08:06 AM
camaro 22's Avatar
there's a tech article on this, you should check it out.
Old Mar 27, 2001 | 03:50 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The solenoid can be added to your existing power pull down hatch motor assy. You just need to get one along with a relay and switch from a coupe. I added it to my convertible. Convertibles have a tonneau release rather than the hatch release. I now have both. Get a Helms manual for the wiring schematic.
Old Mar 27, 2001 | 03:54 PM
lonsal's Avatar
Old Mar 27, 2001 | 05:00 PM
92RSMAN's Avatar
I have a 1992 RS with power pull down. but with no switch release button. I found a wiring harness with three connections under where the switch is located and I found a little black box what are they?
Pure Black 1992 RS Camaro
CHECK OUT MY SITE! http://www.angelfire.com/ne/92rscamaro/index.html
Old Mar 27, 2001 | 08:49 PM
92RSMAN's Avatar
btt i really wanna know what the harness is
Old Mar 27, 2001 | 10:13 PM
lonsal's Avatar
If that lil black box has large gauge yellow wires coming from it, leave it alone. It is a sensor for your air bag (aka SIR Supplemental Inflation Restraint).
90 RS Convertible
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Mar 27, 2001 | 11:56 PM
86Tra/maro's Avatar
Thanx guys for the info! I have a 84 z28 in my yard with the pwr release in it. I'll just take it off that car & install it on mine.
thanx again!!
njdaewoo
Old Mar 28, 2001 | 08:27 AM
92RSMAN's Avatar
ok kewl ill leave that alone i noticed it has yellow tape or sumthing on it.. but theres a little black harness in there too its got three little connections in it.. maybe ill go and buy a manual to research....
Old Mar 28, 2001 | 10:18 AM
lonsal's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 92RSMAN:
maybe ill go and buy a manual to research....</font>
Check eBay for the Helms manual. They are the only ones worth a damn. The Helm manuals run $90 new. With tax & shipping it cost me $108 and change a year ago for my 88 Camaro Helms manual. 8^(
Old Mar 28, 2001 | 01:29 PM
92RSMAN's Avatar
sounds good lonsal thanks a million...Tyler
Old Mar 29, 2001 | 05:20 PM
lonsal's Avatar
Something I forgot to add. I believe the 92 was a unique year. It has a square style hook on the hatch and a motor with a flat spot on one side. You can't interchange it with the older style without replacing both pieces. We tried to swap a 92 motor into the pull down assy of a 87 and it didn't work. Physically it fits OK. But, it pulled down too far and fried the motor. The internal limit switch must be different. Also your 92 style latch has a funky feature forcing you to allow the moitor to power the hatch all the way up before it will release the hook. Prior years can pop the hatch and lift it right away, before the motor has had a chance to come up all the way. If you have good strong gas struts the hatch will rise up automatically when you pop the release switch. Good luck, Lon.
90 RS Convertible
Old Feb 13, 2008 | 11:28 PM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Re: Can a power trunk release ?????
what did you have to make your convertible trunk power and where did you put the switch (didn't they have them at first until they change the t-tops into converts)
Old Jun 12, 2012 | 04:23 AM
Possumz's Avatar
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 5 Speed
Axle/Gears: 3:42
I hooked mine up to the existing plug under the console and added the relay from another 92. When I hit the button to release it the motor will power up and start to raise up but never releases it. Then it pulls it right back down. I have also changed out the rear relay. I was told I needed to add a ground in the back , but where.
Thanks Deron
gta power
Convertibles
Sep 23, 2015 09:32 AM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
sailtexas186548
Aug 24, 2015 10:11 PM
neekolzun
Aug 24, 2015 04:59 PM
smooth
Aug 18, 2015 06:34 PM
