ok how bad is this?
Old Mar 31, 2001 | 08:18 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
ok how bad is this?
my camaro is sitting at home while i am at school. my parents told me that one of the tires has gone flat. i guess just a slow leak.anyway how bad is it that the cars sits on the rim with the deflated tire? it is not being moved or anything it is just sitting so is this bad.
350 vette engine
aluminum heads
235/60R15 BFgoodriches
3"flowmaster exhaust
20% tint
hatch wing
2 12"kicker solos
300 watt sony amp
Old Mar 31, 2001 | 09:00 PM
BadBowTie's Avatar
It has been my experience that a rim sitting on a flat tire is not good for the rim or the tire, more so for the rim if it's aluminum.
Old Mar 31, 2001 | 11:08 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
Its not that bad, cause you didn't drive on it, or anything like that. Just get it fixed so you can drive ASAP
Old Apr 1, 2001 | 01:05 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
thanx alot for the help. i don't get to go home till a month so that is when i will be able to fix it.
350 vette engine
aluminum heads
20% tint
hatch wing
2 12"kicker solos
300 watt sony amp
Old Apr 2, 2001 | 04:13 PM
camaro6spd's Avatar
can't you have your parents fill it with air?? Or at worst with Fix a Flat??
Old Apr 2, 2001 | 11:08 PM
Camaro_hunter_d's Avatar
Working as a mechanic for the last 6 years I can safely say that while sitting still the rims will suffer no damage, the tire on the other hand will get damaged...
Old Apr 3, 2001 | 12:41 AM
86ZRICHIE's Avatar
could be a bead leak, that happens a lot when they use clamp over weights instead of stick on ones, if that's the case take it to where you got the tires and tell them to put on the stick-on ones
Old Apr 3, 2001 | 07:36 AM
Aaron87SC's Avatar
If that tire sits flat for a month get a new one when you get home. It's going to be completly shot. The rim should be ok though.
1987 Camaro Sport Coupe LG4
700R4 with 2.73 open rear
Hypertech chip, 180* stat
Dual snorkel air cleaner with K&N air filter
CK rods with B hanger
Hooker catback
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
